Layered epoxy inlay #10: eye and teeth
Blog entry by JoeyG posted 01-22-2012 02:17 AM 2201 reads 0 times favorited 5 comments Add to Favorites Watch
« Part 9: Problem Fixed Samples Made Part 10 of Layered epoxy inlay series Part 11: Calling it done................for now »
Hello, it’s been awhile since I’ve had a chance to work on this one. Tonight I carved out the white of eye and the teeth. Everything went great until I went in with my knife to clean up the teeth and make the points sharp.
I have made a new discovery that I never thought about before. It seems that when the epoxy hardens with the graphite from the pencil lead it becomes very hard, but very brittle. With the paint it is a little more flexible. I managed to chip it around a couple of the teeth and will most likely have to go back, and put the black epoxy back in again. That’s not to big of a deal, I’ve already had to do it once. What’s that old shop saying, We do it right because we do it three times? LOL. But this has let me to think about the brittleness of the epoxy. If the wood swells enough could it put enough pressure on the epoxy to shatter it? I don’t know but that would suck. With the acrylic paint it retains a bit of elasticity. It may be worth being very careful and using the paints. At this point I am not really sure. I guess as I do more projects and try more variations, I will find one that works perfectly. I must say, that I am happy with the way it is coming together, and with the exception of using to much paint and a couple of chips I feel good about the whole project so far. I expected some challenges and I’ve had a couple.
So here is the face with the carving done. Sorry the picture is so bad, I don’t know what happened and I didn’t check until the next stage was done. If you look to the left side of the mouth you can see the chips around the teeth.
In the next picture I have painted the cavities with a metallic white acrylic paint. This picture came out a little bit better.
Now I will let the paint dry over night and try to get the epoxy into it sometime tomorrow. I’ll get the next episode up as quickly as possible. As I stated before I am in the middle of the first big cabinet job out of my home shop. Well, it’s not really big, unless you look at the fact that my shop is a one car garage. I am also remodeling my shop and hope to be able to post pictures of it soon. Please bare with me and I’ll get us all to the end of this part of it.
Thanks for joining me
Joey
-- JoeyG ~~~ http://www.facebook.com/JHGWoodWorks
5 comments so far
35097 posts in 4270 days
#1 posted 01-22-2012 02:45 AM
Joey: Looking great. take your time.
View jaykaypur's profile
jaykaypur
4017 posts in 2278 days
#2 posted 01-22-2012 03:05 AM
Looks like you are “gittin’ ‘er done!”
As far as the “dremel” box/thing goes, how about something like this———-make a box that is higher in the back than in the front. Have say…3 drawers in the front of the box and then use the carving as a lid or as an inlay of a lid that opens up and reveals a “tray” on the top…above the drawers. The lid could also have a raised edge on the front of it that would hold whatever bits/etc and/or the tool itself while you were working. Just some ideas to ponder.
You aee doing an amazing job on this and I am learning a lot by following along. Thanks.
-- Use it up, Wear it out --------------- Make it do, Or do without!
View lanwater's profile
lanwater
3111 posts in 2804 days
#3 posted 01-22-2012 07:50 AM
Now it’s looking really scary…
I think once you are done with this project, it will be a good reference on working with and mixing epoxy.
-- Abbas, Castro Valley, CA
116804 posts in 3447 days
#4 posted 01-22-2012 08:17 AM
I second the scary comment.
View JoeyG's profile
JoeyG
1275 posts in 2495 days
#5 posted 01-22-2012 03:49 PM
Thanks guys. I am liking the dremel box idea. I also like the idea of using the “faceplate” as a medallion in a larger lid. Once I get some bigger projects out of the way I will start on the box. That can be a whole new blog series.
