Porch Glider #4: More Seat Back Progress
Blog entry by Jimi_C posted 491 days ago 680 reads 0 times favorited 0 comments Add to Favorites Watch
« Part 3: Starting Seat Back Part 4 of Porch Glider series Part 5: Back Building »
Got all the curves cut on one half of the slats, and then used a Microplane rotary shaper with a follower bearing to duplicate the patter on the second half of the slats. I prefer the Microplane over a standard router, since this is end grain and would have been a major PITA to do without blowout.
I misread the plan, and ended up cutting one of the slats too short by about half an inch, so I improvised the curve pattern on the tops of the slats. I think it came out pretty well, but we’ll see once it’s all assembled.
Next I need to select a piece for the center slat, and then start screwing things down to the bottom brace. I also still need to scrape/sand all of these pieces too…
-- The difference between being defeated and admitting defeat is what makes all the difference in the world - Upton Sinclair, "The Jungle"
0 comments so far
