Butcher Block Kitchen Table #9: First Coat of Stain Is On
Blog entry by Jimi_C posted 07-30-2010 04:05 AM 1578 reads 0 times favorited 1 comment Add to Favorites Watch
« Part 8: Glued Up Part 9 of Butcher Block Kitchen Table series Part 10: Base Frame Done »
After testing out my sample piece, I decided to go for it with the table. This is a learning experience after all, isn’t it? :) Sanded out the second coat of conditioner this morning before work, and when I got home I started applying the stain. Here’s the result:
Overall, the process was easy – wipe on, wipe off – just kept trying to work in small sections so the gel stain didn’t dry too much. One minute max, and I went back and started wiping excess off. The only thing I’d change is the application method – cloth rags were way too messy for the application (and difficult to get into some corners). I’m going to get some foam brushes tomorrow, to make application of the second coat a bit easier. I also need more light… after the fact I noticed a spot or two where I didn’t get all the stain off, so I just took a few light swipes with some thinner to get the thick spots off – I figure it’s easier to add color than remove it once it’s on and dried completely.
So, now I just need to wait 24 hours or so, then I can start the second coat.
-- The difference between being defeated and admitting defeat is what makes all the difference in the world - Upton Sinclair, "The Jungle"
1 comment so far
View Robb's profile
Robb
660 posts in 3838 days
#1 posted 07-30-2010 06:22 PM
Looking good! Thanks for taking the time to share.
-- Robb
