Beginning Woodworker Just Starting Out #6: New Toys
Blog entry by Jimi_C posted 07-01-2010 06:50 AM 1400 reads 0 times favorited 5 comments Add to Favorites Watch
« Part 5: My Future Workshop Part 6 of Beginning Woodworker Just Starting Out series Part 7: I injured myself on a SawStop today... »
Well, one of these I actually got a while ago, I just haven’t had any time to play with it…
I got the #8 late last year, and it has sat around due to the fact that it had a lever cap that was cracked in half (in the picture, it’s in the bottom right). Well, I finally snagged a new lever cap off of ebay, the same day I finally won a #71.
I’ve dated the #8 to 1910-1918, based on the patent numbers, adjusting knob size, etc., and the seller of the replacement lever cap put the date in the 1920’s. The tote is cracked off at the top (pretty common from what I’ve seen), and it looks like it was broken in half at some point and repaired. It has a little bit of a wiggle to it, so I think it may have another crack in it around the base, so I may end up replacing it – I’ll have to see. Considering the weight of the #8 and the amount of cracks already on it, I’m leaning towards replacement. Beyond that, the only major damage to the plane is on the front edge, which has a corner taken off the casting where it starts to rise up (visible on the left side of the picture). The lateral adjuster has a pretty severe bend in it, and I don’t really want to attempt straightening it out for fear of cracking it – so if I do replace the tote I may need to cut a little off the top myself to all for the bend.
The #71 is in fair shape – one of the knobs has a pretty good crack in it, most likely from over-tightening the screw. That should be an easy fix with some CA glue and sand paper. There is no depth stop, but I’m not too concerned about that since I primarily plan on using this to true up dadoes, etc. – not route them from scratch.
So, I’ll be looking to pick up some Evaporust soon, and start letting these soak :)
-- The difference between being defeated and admitting defeat is what makes all the difference in the world - Upton Sinclair, "The Jungle"
5 comments so far
View swirt's profile
swirt
2646 posts in 2938 days
#1 posted 07-01-2010 04:40 PM
Sounds like your no.8 was dropped on a hard floor once or twice. That’s too bad, but if it is still flat, you should be fine with a new tote on it. I have a No7 of the same vintage and it works great.
View Div's profile
Div
1653 posts in 2906 days
#2 posted 07-01-2010 09:44 PM
Don’t want to make you jealous but found a #8 not so long ago that still has the varnish on it! Never ever been used! I’m actually wondering if I should use it, so it just sits in my plane cabinet, looking at me while I do jointing with my trusty #7.
-- Div @ the bottom end of Africa. "A woodworker's sharpest tool should be his mind."
View Jimi_C's profile
Jimi_C
507 posts in 3201 days
#3 posted 07-01-2010 10:13 PM
@div: Nah, not jealous. But if it’s in that good a shape and you’re not using it, I’d sell that sucker on ebay in a heart beat – they go for quite a bit :)
@swirt: Yeah, probably a good drop or two – no other cracks on the body though so I’m happy about that. I haven’t tried lapping the sole yet, so I don’t know exactly how flat it is, but I’m not too worried about it.
Beginningwoodworker
13345 posts in 3639 days
#4 posted 07-01-2010 10:20 PM
Congrats on your new toys.
View Div's profile
Div
#5 posted 07-01-2010 11:24 PM
Jimi, you don’t understand. I LOVE my planes. I don’t use it yet cause it is just so pretty in its coat of varnish!
I’ll NEVER sell any of my babies!
