So It Begins...
Blog entry by Jimi_C posted 08-16-2009 04:48 AM 1078 reads 0 times favorited 7 comments Add to Favorites Watch
Just got back from the big box store with some supplies, mostly some pine and MDF, in order to build a work bench. I’d love to start with a nicer design, however my lack of a thickness planer leads me to believe that I would not be able to execute it properly. So I’m setting my sights a little lower, with this nice and easy torsion box design by Tom Caspar, from an old issue of Woodwork Magazine.
I like the simplicity of the design, and the fact that you can build it out of cheap materials with minimal tools. Since I do have a chop saw, I expect this to go pretty smoothly (famous last words of course). I’m modifying the design a little bit, using 1”x4” boards for the torsion box grids instead of 2”x4”s and 1/2” MDF for the skins instead of plywood. I figure this shaved some decent $$$’s off the bottom line, especially when buying the materials at the big box store instead of a lumber yard. I’m not going to worry about the vise/dog holes just yet, but I plan to trim the entire top torsion box with nicer pine when I do the dog holes. I’m confident the torsion box will have plenty of strength, and I plan to use more beams for the grid than Caspar’s design calls for (1 every foot depth wise, and 5 running the length).
Other minor design changes:
1) I am not going to have a tool tray towards the rear, as I’d rather have a full 2’ depth to work and keep bench tools.
2) I’m going to liquid nail the skin to the grid, as I think this will give me more time to assemble. Since this will be my first glue up, I’m probably just being a chicken. I think this will ensure a strong torsion box though, and will compensate for the 1-by’s lack of quality.
So, I’m sure this is going to take way more than a weekend (my goal is a torsion box a day). But hopefully I’ll have a workbench before too long, and I’ll definitely be posting updates on my progress!
-- The difference between being defeated and admitting defeat is what makes all the difference in the world - Upton Sinclair, "The Jungle"
7 comments so far
35120 posts in 4399 days
#1 posted 08-16-2009 04:53 AM
Good luck on the build. I’m want to try a thinner tortion box for a drafting/drawing table.
View papadan's profile
papadan
3584 posts in 3367 days
#2 posted 08-16-2009 04:57 AM
Sounds like a plan Jimi, might rethink the supports. Need the 2x material to drill the dog holes into. Might use them just where the holes will be and the 1x everywhere else.
13603 posts in 3339 days
#3 posted 08-16-2009 04:59 AM
sounds good ,
just make sure that it is flat at the glue up ,
any deflection will be your forever . and yes ,
good luck .
keep us posted .
View Jimi_C's profile
Jimi_C
507 posts in 3233 days
#4 posted 08-16-2009 05:35 AM
@papadan: Good point. I think I’ll double up the front 1-by in a king-stud configuration to give it extra thickness for the lag screws. The dog holes are actually formed in that design by three layers of 2×6 pine attached to the front, with space left at the end for the vise, but I’ll need something sturdy to put the lag screws into.
117091 posts in 3576 days
#5 posted 08-16-2009 05:44 AM
A good useful project good building to you.
View John Ormsby's profile
John Ormsby
1285 posts in 3735 days
#6 posted 08-16-2009 06:30 AM
You could also use 1/2” MDF for the torsion box grids instead of 1x material. It is more stable and very strong when glued up as a torsion box. Have fun.
-- Oldworld, Fair Oaks, Ca
Jimi_C
#7 posted 08-16-2009 07:03 AM
@John: I thought about it, but figured it’d be a pain to rip all those thin strips of MDF from the big sheets. Being alone, those 4×8 sheets of MDF are unwieldy, and ripping them down with a circular saw didn’t sound too fun.
