Router Table #2: Pictures and current progress
Blog entry by Jamie posted 236 days ago 1070 reads 3 times favorited 7 comments Add to Favorites Watch
« Part 1: Getting this project off to a late start on Lumberjocks Part 2 of Router Table series Part 3: More progress »
Well this one is for Karson. Here are some pics of the new router table currently in construction.
This picture is just a view from the front. The top consists of 2 pieces of 3/4” MDF glued together sandwiched between a top and bottom layer of black formica. I have not added the solid oak molding around the table top yet, but it’s ready to go. Probably will happen tomorrow, along with the face frame for the cabinet carcass. The top will be a bit over 25” X 36” when the oak molding is on. By the way, the top is not mounted yet. I just placed it onto the cabinet for the pics. You can see the drawer fronts inside the cabinet. The fence is in pieces right now and has not been assembled yet. It is made of MDF. I still have to get some laminate on it, drill some holes, create the dust collection port and fence faces, etc. I am waiting on my t-track to arrive also. If you look closely, you can see the pocket holes in the carcass on the inside I did with the Kreg jig. Awesome.. Just awesome!
Here is the router table at an angle. The PVC piping on the table will attach to the back of the cabinet for dust collection. The side port off of the PVC pipe will be attached to the fence dust port with clear corrigated flexible tubing. Please excuse the mess in the shop. I am going to try to get most of the shop cleaned up this weekend. This was the first time I had ever laminated anything, and it turned out great. The sawdust on the table makes it look like it is messed up in the pictures, so please ignore this. You can see on the top front part of the side, there is a 3/4” X 3” piece of solid oak that runs across the front for additional stability. I did the same on the bottom of the front and back of the cabinet to keep the table from sagging any. I should get quite a few years out of this one.
In this picture you can see the dust collection port (4”) on the back of the cabinet, and the back of the fence. The only visible pocket holes are 8 on the back. The rest were done within the cabinet where the drawers will hide them. I wanted to do these on the inside also, but there wasn’t enough room within the side drawer areas to screw them in properly. I will hopefully plug the ones on the back tomorrow.
This is a distance shot of the router table. The small PVC fitting will go into the fence dust port to attach the hose. I placed small temporary castors on the bottom to move the cabinet around until I can get some good locking castors.
This is the cabinet dust collection area that will house the router. I kind of followed what seems to be the standard for this. I still have some final cleanup and sanding to perform before finishing.
Here is a closer pic of the fence back. I still have a lot of work to do to get this sucker finished. You can see the table saw that I restored a while back with the Delta T2 fence in the background. Still works like a charm.
This is a pic to show that the fence has not been assembled yet.
Just another pic from the back of the cabinet.
I’ll start keeping up with the pics during the progress of the project. I have just been so anxious to get this thing done to start using it.
-- Jamie, Kentucky
7 comments so far
20707 posts in 718 days
posted 235 days ago
Thanks for the pictures, Jamie. I know that it is difficult to keep a documentary going when you are in the middle of a project since you have to break your routine and concentration (not to mention take time later to post them). But a construction post like this does convey a lot of useful information and is fun for the rest of us to follow your progress.
By the way this is looking pretty good. It certainly is an inspiration for me, personally, to get out in the shop and start on my version.
View bluchz's profile
bluchz
143 posts in 269 days
posted 235 days ago
Man that looks great, hope mine turns out that well.
25802 posts in 1296 days
posted 235 days ago
Thats looking great Jamie.
And – - – I thank you for the pictures.
View Grant Davis's profile
Grant Davis
481 posts in 804 days
posted 235 days ago
AWESOME, thanks for the inspiration. I need to get off my you know what and get busy.
-- Grant...."GO BUCKEYES"
View Chris's profile
Chris
300 posts in 253 days
posted 235 days ago
Thanks for posting, and thanks particularly for the detailed pics!
-- Chris
View Jamie's profile
Jamie
146 posts in 710 days
posted 234 days ago
Thanks for the comments guys! I got out to the shop yesterday and got some work done. Primarily the face frame to the cabinet, and the dust collection port on the back. I will be installing the trim around the table top today, and hopefully working on the drawers and door. I’ll be posting a new entry with pictures this evening!
-- Jamie, Kentucky
View Woodchuck1957's profile
Woodchuck1957
950 posts in 660 days
posted 234 days ago
It takes alot of time, doesn’t it. Would be nice to know how many hours and the price of materials. Last year I made a portable router table, it turned out nice in my opinion, and it works a heck of alot better then the Craftsman setup I had used for too many years, but I’m not sure that it was worth it, probably would of been better off just buying one, but I guess thats the way some of us are, spend more time on stuff then it’s worth, like the air filtration box I’m building with a furnace blower, over doing it again. It looks good though Jamie, nice job so far.
