Since I have installed the Delta T2 fence on my Craftsman tablesaw, I have had a few people asking how I installed it, especially, how I installed the fence so that it would zero properly. For those that are thinking about installing this fence on a craftsman, you WILL have to drill new holes in the rails. You can use one of the existing holes, but you will not be able to ‘0’ the fence.
I wish that I had taken pictures of each step to further clarify the information listed below. Looking back now I realize that it would have helped quite a few people. I may be able to do some sketches and post them here…
First, I went ahead and attached the square tubing to the front rail. Then with a pencil, I made a mark on the front rail at ‘0’ on the measuring tape that is attached to the square tubing.
Then, I disassembled the front rail and tubing. I had a ‘0’ reference point on the front rail from the previous step. I placed both front and back rails together so that I could get my ‘0’ reference point transferred from the front rail to the back rail.
Next, I placed the fence on the tablesaw and moved it to where the zero position would be (against the blade), as if the fence was actually attached, making sure to square the fence with the table. The T2 fence has a plexiglass (or clear plastic) sight where you read the attached measuring tape through. I made a mark on the table where the reference line on the sight was. I then drew a line at that point on the saw top from the front to the back, of course making sure that the line was square to the table.
Next, I layed the front rail on the top of the saw, matching up the ‘0’ reference mark on the rail to the line that I drew on the saw table top. I then measured 1.75 inches from each side of the saw table and drew a line on the front rail for each. I did the same for the center of the table at 10”. I then did the same for the rear rail.
I then drilled the holes. I actually offset the holes a bit higher and did not align them with the existing holes that were in the rails because I wanted to make sure that the fence was as close to the table as it would go without scraping across the table when you moved it or riding too high above the table. The fence sides are adjustable up and down, so you do have a bit of tweaking there too. If you look at the blog, you will notice in the fourth picture down on the before and after pictures, that the holes that mount the rail are up slightly from the original holes.
Once you mount the rails and put the fence on, you may have to adjust the plexiglass sight on the fence a little. It is adjustable side to side, but when I installed it, I barely had to make any adjustment to it at all.
Like I said before, I really was really worried that I would mess it up, but if you take your time and make sure that all of your measurements are accurate, everything will work out fine. All I can say is that it made a 200% improvement on the tablesaw. I have been using it now for a few weeks and it is extremely accurate. It’s nice being able to set the fence on a measurement, and not have to double check the fence to the blade to ensure that what it says is what it’s going to cut.
I am by no means an expert at installing table saw fences, and really, I was taking a big chance on messing up the fence and it eventually not being usable (or returnable). I took my time thinking about how I could accomplish the installation. There may be a better way to install this fence on a craftsman tablesaw, but this way worked for me.
Hope this helps… as stated above, you will have to drill all new holes in the rails to get it to work right.
-- Jamie, Kentucky
7 comments so far
home | projects | blog
20636 posts in 716 days
posted 675 days ago
Hi Jamie,
I couldn’t get mine to work on my Craftsman saw (See the post I left Sammy). My wings are 1 3/8” thick and by the time I lower the angle iron in order to mate the fence with the saw surface I would have had to drill through the edge of my wings- which would not have worked. So I am guessing that you ran into the same problem which is why you opted to drill out the rails rather than the wings.
Thanks. This post clears up my problem. I am not sure if I am willing to give it another try or not since it would not be possible to return the fence but I will think about it.
Sammy
13 posts in 676 days
posted 674 days ago
Thanks Jamie, makes perfect sense and that was the direction I was thinking but was a bit worried about the fence clearance. I’ll continue to dry fit and test prior to marking the holes for drilling. I’ll take pictures along the way to hekp out any one else with the same model saw. My wings are 1 1/2 inch think so I should be able to aviod the problem that sbryan55 had. Again thanks for the tips and you just made my weekend!
-- Sammy, Pittsburgh PA
John
5 posts in 675 days
posted 674 days ago
Thanks for sharing your experience with this installation. I plan to attempt this on my Craftman 113 series.
Jamie
146 posts in 708 days
posted 674 days ago
Sbryan55, Good to see another hillbilly on here, but sorry that it won’t work for you. I guess that I should have stated that the table must be 1.5” thick.
Sammy, Glad that this helps you. One other reason that I liked this fence is because the fence faces are aluminum and attached by t-bolts which makes them easy to take off and attach some extruded aluminum sides with all kinds of t-tracks. Imagine all the clamping and jigging possibilities.. If you could get some pictures during the install, that would save alot of people the headache trying to decipher my instructions..
John, It should work on any Craftsman 113 series 10” table saw as long as the table is 1.5” thick..
-- Jamie, Kentucky
Sammy
posted 672 days ago
Thanks for all the help guys! This website is great and the people are fantastic with all the help. When I’m done I’ll try and take Jamie’s experience and match it up with mine to create a working document to described how to install this great fence.
johnd
2 posts in 658 days
posted 658 days ago
HI Jamie,
I am working on doing this same retro fit to a similar vintage craftsman. I believe mine is a 103xxxx model I think it was made by Seely making it late 40’s early 50’s it has just the one dial on the front that controls the blade height and then you push it in to change the angle.
Great writeup and very helpful. Did you have to enlarge the existing holes that mounted the original fence? The holes in the saw mounting the original fence on mine are much smaller than the bolts that came with the delta t2. Just curious. Thanks in advance.
-John
Ben
49 posts in 258 days
posted 258 days ago
Hi Jamie,
I followed your directions exactly and it worked like a champ. I have a craftsman 113.298240. Thanks for the detailed instructions. One little trick I found was to put a strip of blue painters tape across the front and back of the table along the line where the top of rails need to line up. This will make sure you get the rails at the perfect height before you start drilling into your table top. I also used a drill press to drill the holes in my rails.
