I needed a jig to make a lazy susan, my blog is at;
http://lumberjocks.com/jocks/Grumpy/blog/6612
This jig was not my design but came from an article in a magazine. It is fairly simple & I thought it might be worth sharing.
There are 3 wooden components & a handful of metal bits.
A 1/4”X6” disc can be stuck to the item you want to shape or a 1/4 pin can be screwed into a hole in the centre of the item as in the above photo.
A 4 1/2”X 1/2” piece of desired length is then needed to mount the router on. The router is actually mounted on a separate piece of shaped wood at the end.
A 1/4” slot runs along the centre of the longer piece & a 1 1/4” groove is cut on the under side.
I used a metal piece to act as a pivot & also act as a slider along the groove in the longer piece.
The white pieces of tape under the router base was added for this cut to adjust the height because double sided tape was used under the centre piece.
Thats all folks.
9 comments so far
kolwdwrkr
home | projects | blog
2262 posts in 490 days
posted 360 days ago
Nice jig, it helped produce a nice project. Thanks for sharing!
lew
4515 posts in 655 days
posted 360 days ago
Great looking jig, Grumpy!!
Did you have any trouble with the tape coming loose?
Chris Davis
558 posts in 882 days
posted 360 days ago
That is a really nice jig. I made a quick one before but I put new screw holes in it each time a do a new size circle and I also drill a hole in my work piece. Thanks for sharing, I may try to build one sometimes.
-- Watch live video from our shop. http://wwbeds.com/live.htm
Thos. Angle
4013 posts in 862 days
posted 359 days ago
I built one of these a couple years ago but didn’t get it quite right. Thanks for sharing.
-- Thos. Angle
25871 posts in 1300 days
posted 359 days ago
Grumpy: It looks great. I like the idea of using double faced tape to hold the center board in place and not having to drill into your piece.
I see you splurged and used some of your local high priced Australian woods for the slide bar.
odie
1603 posts in 740 days
posted 359 days ago
Not bad for an old fart … what does it do ??? LOL
definn
30 posts in 416 days
posted 359 days ago
Good Thought, made something similar when my Class made 40 round tables for a food service.
-- Karl, Wyoming
14949 posts in 751 days
posted 359 days ago
Thanks for the comment everyone
posted 359 days ago
Odie, I thought you knew. It’s a halo making jig in case you break yours. LOL
