Personal Stamps for Wood
Blog entry by Grumpy posted 08-06-2015 03:43 AM 1835 reads 0 times favorited 13 comments Add to Favorites Watch
Hi Jocks. I am after a stamp for either burning or hammering my initials on finished projects.
Does anyone out there know where I can get a reasonable priced custom made stamp or even a kit to make one. Only needs to be 10-15mm diameter.
Any help would be greatly appreciated.
13 comments so far
View woodworkerguyca's profile
woodworkerguyca
30 posts in 1098 days
#1 posted 08-06-2015 04:57 AM
Try here: http://www.shapeways.com/product/65KAUZQAF/branding-iron-for-a-bic-classic
this https://www.shapeways.com/product/PYV2K7WF8/name-branding-stef
or a more technical version http://www.thefrankes.com/wp/?p=1893 (also using Shapeways)
I have not tried this personally yet as I’m convinced I can make one that will fit a dollar general soldering iron…somehow.
There’s a good chance I’ll break down and just order one when I realize I am too ambitious.
View DKane's profile
DKane
14 posts in 1079 days
#2 posted 08-06-2015 05:01 AM
Why not just use a wood burner, or soldering iron to burn your signature/logo into the project? Just curious, not judging.
24033 posts in 3905 days
#3 posted 08-06-2015 05:03 AM
Thanks Di but I don’t have the skills of an engraver.
View Sam Shakouri's profile
Sam Shakouri
1200 posts in 3141 days
#4 posted 08-06-2015 09:36 AM
Try this one. it may help you.
https://www.etsy.com/au/shop/ArtisansOnline
-- Sam Shakouri / CREATING WONDERS WITH WOOD.....Sydney,Australia....
View Roger's profile
Roger
20929 posts in 2858 days
#5 posted 08-06-2015 11:14 AM
Even the plain ones are a bit pricey. Good luck with whatever you find.
View helluvawreck's profile
helluvawreck
31707 posts in 2920 days
#6 posted 08-06-2015 01:40 PM
Grumpy, another way that you could go about this would be to get someone with a laser engraver to engrave you some discs with your logo on it. Then all you would have to do is to mount them flush with a boring bit. The laser would cut these out for you. A trophy shop in your area could make these for you. Your logo could be very intricate if you liked.
helluvawreck aka Charles
#7 posted 08-06-2015 11:04 PM
Some good tips there. Thanks Jocks.
View karbster's profile
karbster
1 post in 1074 days
#8 posted 08-10-2015 04:12 PM
They are not cheap but Rockler sells custom engraved branding irons both electrically heated and torch heated.
http://www.rockler.com/project-supplies/wood-branding-irons
#9 posted 08-16-2015 06:39 AM
Keep a lookout Jocks.
I have ordered a personalised one from China, made to my design for $35USD.
Will provide details when received.
The company has be very easy to deal with so I am expecting a good result.
#10 posted 12-11-2015 03:05 AM
It is 6 months since I posted this topic and I have been a bit lax in updating it.
But the result is worth sharing.
I found a company in Hong Kong that would make me a personalised stamp for burning on wood.
I dealt with a man named Jensen who was extremely helpful.
The company is called ‘Etsy’
www.etsy.com/hk-en/shop/ArtisansOnline
I designed the stamp and emailed it through with the size I wanted and they made it to order. Very satisfactory result.
The cost of a 15mm stamp with my initials inside a circle was $35USD.
You get a threaded shaft (like a 1/8th” bolt shaft without the head) that screws into it.
You can also buy a special heating iron (looks like a soldering iron) for burning on to wood.
I just use the BBQ wok for heating.
Overall a good result for burning onto projects.
View Dark_Lightning's profile
Dark_Lightning
3171 posts in 3163 days
#11 posted 12-11-2015 10:17 PM
Interesting. What sort of format did you give it to him in? .jpg?
-- Random Orbital Nailer
#12 posted 12-12-2015 01:30 AM
No, they preferred pdf or .ai (whatever that is). I gave it to them in .pdf format and it came back exactly as I designed it.
This one is a bit over done on the burn. Should improve on it with practice
Dark_Lightning
#13 posted 12-19-2015 03:14 AM
Makes sense. PDF stands for Portable Data Format and is readable by a lot of software. All it has to do is read black pixel/white pixel, in this case. Easy peasy. I have a shop logo, so it might cost a little more, since I want it a little bigger than 15 mm. .ai is an Adobe Illustrator format, so Adobe is their software of choice. Works for me!
