Emergency Toilet Door-My Solution
Blog entry by Grumpy posted 115 days ago 613 reads 0 times favorited 10 comments Add to Favorites Watch
Some time ago I posted a blog asking if anyone had any ideas on a two way opening door system for a toilet entry.
http://lumberjocks.com/Grumpy/blog/8405
I got some good ideas from that & also chased the World wide web. Many thanks to those who responded.
There are manufacturers that make systems just for this purpose but they are generally expensive & some require considerable modification to the door jamb structure which was what I wanted to avoid.
After a lot of thinking & not much doing I had an idea that was simple, cost effective & practical.
I used a bi-fold door mechanism which was pivoted at the top & bottom of the door (no hinges). I used the track & the pivots from this kit.
Photobucket;Photobucket
This allowed the door to open in both directions.
Next came the issue of a door stop to allow the door to open & close internally under normal use & to open outwards in an emergency. The door was free to swing in either direction because I had reduced the width so that it fitted inside the jamb. I needed something to act as a stop that could also be moved in an emergency to allow the door to open out.
The kit for the bi-fold door system had a spring loaded overhead plastic runner for a second door. This was not needed because there is only one door. But it had a use as a door stop. I cut the runner so it had one flat side & the rest was the original circular section. The flat side was to act as a door stop.
In an emergency the stop could be pushed in so it was flush with the jamb allowing the door to open out. The red was added graphically for effect.
There was one more problem Grrrrrr @#$%$%%^^&&(*&(
The door needed about 1/4” gap between it & the jamb to allow it to pivot both ways. This resulted in a privacy issue because there was some limited view of the inside.
To overcome this I added a privacy strip either side of the jamb. It allowed the door to pivot but blocked any view of the inside.
This is the profile.
This photo is with strips fitted to the jamb
As you can see the project is not finished yet but the idea is the important part.
The total cost was $50Aus (about $41.50US)
10 comments so far
16776 posts in 471 days
posted 115 days ago
Interesting aproach
View Bureaucrat's profile
Bureaucrat
7236 posts in 546 days
posted 115 days ago
Grumpy:
I can see why you have done more thinking than doing. There are a few issues to deal with but it looks like you have this project licked.
-- Gary, South Central Wisconsin. So much to learn, so little time!
View jim1953's profile
jim1953
1601 posts in 736 days
posted 115 days ago
Nice
-- Jim, Kentucky
2379 posts in 235 days
posted 115 days ago
good save !
an interesting fix .
View DAN 's profile
DAN
6439 posts in 877 days
posted 115 days ago
for ten bucks you could of hung a blanket over the door … >grin< ... just kidding …
glad you got something to work for you … hope all is well
14156 posts in 1055 days
posted 115 days ago
work those brain cells.. work those brain cells :D
glad you found a solution.
25794 posts in 1295 days
posted 115 days ago
Grumpy: A great solution. I knew you could do it.
3710 posts in 874 days
posted 115 days ago
Hey Buddy;
Nice solution, very creative.
14920 posts in 745 days
posted 114 days ago
Thanks everyone. If it inspires somene else to a similar job & it potentially saves a life thats great.
View TomFran's profile
TomFran
2513 posts in 888 days
posted 114 days ago
Way to improvise, Grumpy! It’s gratifying to come up with good solutions.
