An adventure in making toys - Old Time Farm Truck #9: Headlamps and mudguards
Blog entry by George_SA posted 05-27-2015 12:15 PM 2145 reads 0 times favorited 7 comments Add to Favorites Watch
« Part 8: Load box Part 9 of An adventure in making toys - Old Time Farm Truck series Part 10: Final Assembly »
I used the end of a broomstick for the two headlamps. I didn’t have a 20 mm dowel and I did not want to fire up the lathe to turn a such a short 20mm spindle and also the broomstick was just the right diameter and it was only a very short piece that was needed. The headlamps will be attached to the engine block with dowels.
I also used two washers and attached them with screws to make the headlamps a bit more interesting
With the mudguards I reverted back to my original plan. While drawing the original sketchup plan I was concerned about the strength of the mudguards as there would be short grain on the roundings which might cause a weak spot. I then drew up an alternative plan changing the mudguards so that they would be made up of different straight grained pieces. After thinking this through again when I started making them, I came to the conclusion that the changed mudguards would in actual fact be weaker than the rounded ones due the the joints in the design.
I used a piece of teak from the scrap bin and positioned the layout in such a way to minimise the amount of short grain on the roundings. They seem to be quite strong.
I printed the mudguards and pasted the pattern to the wood and then I used my bandsaw to cut them out.
I used my homemade spindle sanders to finish the mudguards
-- Sometimes life gets in the way of one's woodworking :)
7 comments so far
View helluvawreck's profile
helluvawreck
32086 posts in 3106 days
#1 posted 05-27-2015 12:46 PM
This is really looking good. I’m going to look back over this blog.
helluvawreck aka Charles
View robscastle's profile
robscastle
5632 posts in 2444 days
#2 posted 05-28-2015 07:39 AM
George,
George,
George…
Wives have an uncanny knack of noticing things missing, regardless of how short it was.
Let me know what ward you go to at The Bay and I will come visit you !
Nice job on the headlights !!
-- Regards Rob
View George_SA's profile
George_SA
385 posts in 2453 days
#3 posted 05-28-2015 08:08 AM
robscastle
#4 posted 05-29-2015 09:40 AM
I see your reply,
does that mean you are already on the floor horizontal and paralysed from a beating and your face is so contorted it looks like a smile on your face ! tee hee
-- Regards Rob
George_SA
#5 posted 05-29-2015 10:43 AM
The broom stick is now too short to be of any use in a beating, so I am safe for now :)
robscastle
#6 posted 05-29-2015 11:00 PM
OK good work George Looking forward to seeing the finished product !
-- Regards Rob
View Dutchy's profile
Dutchy
3195 posts in 2408 days
#7 posted 05-31-2015 05:19 PM
Thanks for sharing George.
-- https://dutchypatterns.com/
