Usually when I want to countersink a larger hole in a smaller hole I use a Forstner bit to drill the larger hole first. The Forstner tip leaves a nice little center hole which enables me to accurately drill the smaller hole all the way through. Sometimes I get overeager and forget to drill the larger countersink hole first. One is then faced with the problem of centering the Forstner bit on a hole. Not so easy!
This happened again the other day and thinking about the problem for a while, I came up with the following solution. Put a dowel in the hole after marking the center on the dowel. After drilling the countersink hole, just remove the dowel.
-- Integrity is doing the right thing when no one is watching.
8 comments so far
GerardoArg1
home | projects | blog
231 posts in 165 days
#1 posted 156 days ago
Great Idea George!!!!! I had the same problem several times … and never came across the solution. I’ll use your system to the next.
-- Disfruta tu trabajo (enjoy your work)
HalDougherty
1820 posts in 1408 days
#2 posted 156 days ago
I had the same problem drilling a hole in a 9/16” aluminum rod to make pillars for bedding in the gunstocks I carve. I don’t have a metalworking lathe, so I worked out a simple jig to center the hole. I drill the 9/16” hole in a block of maple using a 9/16” plunge router bit in my drill press. Then I cut a slot with my bandsaw so a bolt will clamp the block around the 9/16” aluminum rod. Next I clamp the maple to the drill press table and center it by lowering the 9/16” router bit into the hole and lock the maple in place. Then I replace the router bit with a .260” diameter drill bit and drill the hole. It’s centered and the jig is so easy to make, I don’t worry about the cutting fluid messing up the maple jig, I just make another one in a few seconds each time I need one.
-- Hal, Tennessee http://www.first285.com
jeffbranch
69 posts in 824 days
#3 posted 156 days ago
Great idea. I could have used this tip about a month ago. Merry Christmas!
-- http://jeffbranch.wordpress.com
ChrisK
547 posts in 1253 days
#4 posted 156 days ago
Simply genius! I hope I remember that next time I have the same issue.
-- Chris K
Ben Simms
180 posts in 463 days
#5 posted 156 days ago
i made this mistake the other day. nice fix!
-- I played with Legos as a kid and I never had the part I thought I needed, so I learned to improvise. Now I'm an engineer with a woodworking hobby.
87312 posts in 1748 days
#6 posted 156 days ago
Well done.
Charles Maxwell
826 posts in 1978 days
#7 posted 156 days ago
I often have need to open the size of a prior drilled hole. I’ve used your method in the past with good results but, I found that a stepped or tapered drill bit with a follow on forsner bit is a far better solution. And, my need for accuracy is important as the hole I open is typically in a clock. Give it a try.
-- Max the "night janitor" at www.hardwoodclocks.com
Adam
45 posts in 1233 days
#8 posted 156 days ago
Good idea, another soulution is to drill a hole through a piece of scrap, say 1/4 plywood, with the larger forsner bit you wnat to counter sink with and then clamp that hole over the smaller hole. The walls of the pre drilled hole in the scrap will guide the bit into the workpiece without wandering.
-- Adam, St. Catharines, Ontario, Canada
