A Dump Truck Adventure #9: Wheels 01
Blog entry by George_SA posted 01-12-2019 02:43 PM 299 reads 0 times favorited 0 comments Add to Favorites Watch
« Part 8: Bin Part 9 of A Dump Truck Adventure series Part 10: Wheels 02 »
I made a few jigs for making the wheels
1st I made the wheel blanks 10×50 x 50mm for this truck. My final wheel size is 44mm diameter.
I marked 1 corner for consistency on the drill press.
All the blanks for the wheels plus a few spare
Mark the centre of the blank. I only mark one to set up the drill press.
The set up in the drill press with a stop block against the drill press fence.
I used a 25mm Forstner bit to drill the holes for the centre hub.
Then I drill the axle hole (8mm for this truck)
Next step is to drill the decorative holes in the hub (3mm for this truck)
I used my indexing jig for this.
The jig for making the index wheels for the jig
I used SketchUp to make the template for cutting the index slot (5 for thes wheels) Sketchup model
available here
-- Sometimes life gets in the way of one's woodworking :)
0 comments so far
