EDIT 13 Mar 2018
Part 2 explains it more clearly and works for even spaced and uneven spaced fingers.
While thinking about making a joint that is similar to making Box Joints, I came up with the idea to use my
5 Minute Kerf maker and Small Sled to make Box Joints.
It works like this
You use a stop block and spacers and the Kerf Maker on the sled to cut the Box Joint Fingers.
The 1st step is to align everything for the 1st cut.
I switched the spacers and the Kerf Maker around to save my Kerf Maker from getting chewed up by my saw blade. In a perfect world that shouldn’t happen, but alas in the real world it does. The spacers are expendable and therefore it is not a problem if the spacer gets chewed up a bit.
The 2nd step is to make the 1st cut
The 3rd step is to remove a spacer, flip the Kerf Maker and make the 2nd cut
In the following illustration I try to explain why you need to use a Kerf Maker and why it must be flipped after every cut.
The Kerf Maker is used to take the blade thickness into account when making the cuts. If you just use spacers without the Kerf Maker, then the cuts would be out by the thickness of the blade every time.
The 4th step is to remove another spacer and flip the Kerf Maker again to make allowance for the blade thickness and then do the 3rd cut
The 5th step is to remove another spacer and again flip the Kerf Maker and to make the 4th cut
The last step is to nibble out the waste
The above steps describe the procedure to make 2 fingers. If you need to make more fingers, just repeat steps 2 and 3 for every additional finger and make sure that you have enough spacers for the amount of fingers that you want to cut. The amount of spacers = the amount of fingers – 1.
If you need to cut out a waste finger offset from the side then do the setup as in step 1. Then WITHOUT flipping the Kerf Maker remove a spacer before doing the 1st cut. Thereafter proceed with steps 2 and 3 as described above. (See illustration below)
It might seem complicated at first, but basically it boils down to aligning the work piece using a stop block, Kerf Maker and spacers. Then you just need to remove a spacer and flip the Kerf Maker for every finger that you want to cut.
The result is a box joint that is just as good, if not better than box joints cut on one of my other jigs.
A good tight fit.
Just a word of CAUTION! Make sure that you DON’T cut your own fingers while cutting the Box Joint fingers!!!! If you feel uncomfortable with this technique then DON’T DO IT!!!!!!
Even if you don’t use this technique for making box joints, this blog hopefully explains the principle of how a Kerf Maker works.
Thanks for taking a look.
-- Sometimes life gets in the way of one's woodworking :)
1 comment so far
observer100
home | projects | blog
391 posts in 1077 days
#1 posted 02-12-2018 06:49 PM
I see what is going on now … very nice. Very simple yet somewhat hard to understand without studying your nice diagrams a few times.
