A Dump Truck Adventure #2: The engine and radiator Part 1
Blog entry by George_SA posted 01-04-2018 07:27 PM 1599 reads 0 times favorited 5 comments Add to Favorites Watch
« Part 1: Humble beginnings Part 2 of A Dump Truck Adventure series Part 3: The engine and radiator Part 2 & a diversion »
Next up is the engine. I used a darker wood (off cuts lying around, and I’m not sure exactly which type of wood) for the engine block and a lighter wood for the bonnet (I recently learned that in American English this is referred to as the hood )
Next is the radiator
On my first truck (Old Time Farm Truck #5: Engine Block) I glued some thin strips of wood to the radiator to form the grill and loose strips to form the frame. I found that to be a bit difficult to get the spacing right.
On this truck I decided to follow a different approach. For the grill I laminated a dark and light wood together.
Then I squared the top and cut it to width on my table saw. Then I cut slots through the darker wood to make a grill effect. This will be cut to size to fit inside the outer casing of the radiator
On the outer casing I borrowed a technique from Dutchy to cover the end grain with a long grain strip.
After cutting to size I glued a template on to cut out the inside square where the grill will be inserted.
To be continued in The engine and radiator Part 2
-- Sometimes life gets in the way of one's woodworking :)
5 comments so far
View Dutchy's profile
Dutchy
3196 posts in 2410 days
#1 posted 01-04-2018 07:39 PM
This is making me glad!
-- https://dutchypatterns.com/
View htl's profile
htl
4329 posts in 1401 days
#2 posted 01-04-2018 07:49 PM
Great job and love them there HowTo’s
-- An Index Of My Model making Blogs http://lumberjocks.com/htl/blog/116729
View GR8HUNTER's profile
GR8HUNTER
5404 posts in 954 days
#3 posted 01-04-2018 09:00 PM
i think I’m the only one not to blog a build ….this dump truck is going to be very nice ….LOOKS GOOD :<))
View htl's profile
htl
#4 posted 01-04-2018 11:10 PM
GR8 About blogging.
It’s been kinda scary to start showing others how much I really don’t know about wood working.
So for me it has been a show what I’ve learned and figured out by watching others.
This post being a fine example of my watching and learning.
View George_SA's profile
George_SA
385 posts in 2455 days
#5 posted 01-05-2018 06:03 AM
- Dutchy
Great job and love them there HowTo s
- htl
Thanks
i think I m the only one not to blog a build ….this dump truck is going to be very nice ….LOOKS GOOD :<))
- GR8HUNTER
I had a look at your creations and I feel humbled! WOW!
