Concept Ideas using SketchUp #6: How to draw printable index wheels
Blog entry by George_SA posted 12-12-2017 06:51 PM 837 reads 1 time favorited 2 comments Add to Favorites Watch
« Part 5: Scroll Saw Part 6 of Concept Ideas using SketchUp series Part 7: How to make a vernier scale with SketchUp to use on jigs »
Edit
A MUCH EASIER way! There is a website (Hubs Spokes Spindles) that does all the calculations for you (You input the number of spokes the diameter etc.) and generates a printable template.
(If you really want to do it in SketchUp then read through the rest of the blog.)
End of Edit
In the discussion Brian's (Bushmaster) post on INDEXING DISC JIG, EASY PROCEDURE
the question came up on how to make printable indexing diagrams in SketchUp.
I use the following procedure.
Note: this tutorial assumes that you know the basics of using SketchUp.
If you still need to find your way around SketchUp, do a search in YouTube for Sketchup for woodworkers 2017
In this example I used 40 degrees to make a 9 segment index wheel.
-- Sometimes life gets in the way of one's woodworking :)
2 comments so far
View bushmaster's profile
bushmaster
3426 posts in 2521 days
#1 posted 12-12-2017 06:59 PM
Thanks for doing this blog, it is most helpful, I haven’t tried it yet, will when I get time.
-- Brian - Hazelton, British Columbia
View George_SA's profile
George_SA
385 posts in 2451 days
#2 posted 01-17-2018 08:19 PM
