The Nightstands Build #1: Nightstand Progress
Blog entry by Eric_S posted 1158 days ago 1590 reads 2 times favorited 11 comments Add to Favorites Watch
no previous part Part 1 of The Nightstands Build series Part 2: Update, pattern cutting the curves on aprons and legs »
I’ve been saying I would post pics on the nightstand progress for a while so I thought I would actually do what I said. The nightstands are progressing nicely. These pics aren’t really exciting though but its a work in progress. The legs are hard maple and the rest is cherry. THe panels are more of a Red cherry and the top and drawer fronts when finished will be curly cherry.
The legs. On the 4th leg from the left I had to use maple wood filler half way up after partially drilling a mortise in the wrong location. The double mortises are 1/4” and the apron mortises are 3/8”. I still need to cut them to correct length, cut the curves in the sides, and cut a dovetail opening on tops.
Bottom aprons. The tenons were all done on the bandsaw with stop blocks. Much easier to do than relying on my inaccurate fence and table saw, even with the tenon jig I made. I still need to template and create the curve in the bottom of them and groove the top of them 3/8”
Top aprons. Still need groove in bottom for panels.
the front blades. These still need the double tenons and the top ones need dovetails.
My favorite and most used tool in the shop. Its ooooold. Stanley No. 7 with hock blade and chipbreaker. All original japanning. Tote is replaced but isn’t the correct one for it. Also in pic is newer No.5 from the 50’s I think also with hock blade and chipbreaker.
These are the original side and back panel of one nightstand but decided 12 1/2” between the legs was too small ;) so I decided to do bookmatched panels at 17”
Bookmatched panels for the sides of one nightstand. These still need to be flattened and I still have another pair and backs to do.
Odd small scraps from cuts. What should I do with all these uniformly cut tenon shoulders and cheeks from the bandsaw? Hmmm. Suggestions?
Thanks for looking.
-- - Eric Indianapolis, IN
11 comments so far
View Jim's profile
Jim
133 posts in 1493 days
#1 posted 1158 days ago
Make an end grain cutting board with the scraps!
-- -- Jim - Kokomo, Indiana
View Eric_S's profile
Eric_S
1522 posts in 1366 days
#2 posted 1158 days ago
Hmm maybe, it would take some creativity in the design. Not sure if I even have enough for one.
View Thomas Keefe's profile
Thomas Keefe
131 posts in 1580 days
#3 posted 1158 days ago
Thanks for the update Eric. It looks like you are making great progress. In the sketchup plans it seemed
like there were more curves than what I see here. Did the plan change? Thanks for posting.
Tom
Eric_S
#4 posted 1158 days ago
Well the curves are only on the bottom of the legs now instead of top and bottom, but i still have to make them.
View dlmckirdy's profile
dlmckirdy
192 posts in 1304 days
#5 posted 1157 days ago
The pieces that are too small to work would make great smoking chips for the BBQ I just try to smoke with one specie at a time.
-- Doug, Bakersfield, CA - I measured twice, cut it twice, and it is still too short!
View JimArnoldChess's profile
JimArnoldChess
169 posts in 1166 days
#6 posted 1157 days ago
Excellent documentation of your project, Eric! Looking forward to following this. As for the scraps, I bought a garbage can just for my scraps, you never know when you might need an odd shaped piece somewhere or blocks for your clamps, of course the problem is the can gets full then its time to fire up the smoker like Doug said.
I appreciate the detail of your documentation, one of the many reasons I signed on here was to watch you guys in how you do your precision table work. Too often I spend lots of time carving and end up just throwing the board together…I’m learning quite a bit watching projects develop like yours.
Thanks!
Jim
-- http://www.etsy.com/shop/JimArnoldsChessSets
Eric_S
#7 posted 1156 days ago
Smoking chips suggestion sounds good doug, i may have to try that.
Thanks Jim. Maybe in the future I’ll try and include some pics of setups and cutting to help.
View mjacobs's profile
mjacobs
3 posts in 1155 days
#8 posted 1155 days ago
You could always use the scrap chips for a nice game of Jenga.. ;)
-- Mark, Oregon, http://www.smallwoodworkingprojects.com
View NBeener's profile
NBeener
4856 posts in 1345 days
#9 posted 1155 days ago
Eric:
Emotionally, I’m a very awkward mix of:
- cheering on your progress
- grateful for your documentation, and
- waxing more than a touch nostalgic :-)
Good show! Keep it up, Bud!!
-- -- Neil
View helluvawreck's profile
helluvawreck
10466 posts in 1038 days
#10 posted 1005 days ago
This looks very much like the joinery that was used in Peter Korn’s Basic Woodworking. This is very nice work.
View sandhill's profile
sandhill
1978 posts in 2095 days
#11 posted 916 days ago
Nice job, it looks a lot like the ones I am making. When I am home.
