Thorsen House Cabinet #14: Complete! (in a manner of speaking)
Blog entry by EläväPuu posted 06-04-2015 09:40 AM 1295 reads 0 times favorited 3 comments Add to Favorites Watch
« Part 13: Making headway on the glass work.... Part 14 of Thorsen House Cabinet series no next part
The cabinet is in situ! We spent a few hours prepping and mounting the cabinet using four of these superlative products from Whitechapel Ltd: http://www.whitechapel-ltd.com/product//274BF4.html
Generally designed for bed construction, they easily have more than enough strength in terms of shear resistance and weight bearing. Amazing things. I recommend them and Whitechapel highly.
So, the cabinet is complete save for the ongoing glass panel work. The world seemed to have gone through some sort of global 1/4” black-backed copper foil crisis the last month, so this has been delayed….
Previous Solidworks simulation:
...pretty similar!
The lead line texturing was entirely experimental. Our lines were created using two lines of 1/4” foil overlapped on the safe ground edge to create a significant face on the glass. This was cut back and shaped by hand (painstaking) to create more organic movement and constant change in weight. The line was replicated on the back of the glass so as not to make either prominently visible from the other side. Lines were loaded with as much solder as the foil could support and textured using a technique which we figured would work (it did) but had never seen described before. Maybe our first husband and wife trade secret! After black patination, the lines are burnished with steel wool, given a light coat of beeswax and buffed.
I’ll endeavour to post a final closing blog entry and then take this entire piece over to being a “Project” entry.
Cheers!
- Carl
-- "What can be asserted without evidence can be dismissed without evidence"
3 comments so far
View pintodeluxe's profile
pintodeluxe
5654 posts in 2808 days
#1 posted 06-04-2015 04:17 PM
It sure looks nice on the wall. All the hours of careful work are evident in this lovely piece.
View EläväPuu's profile
EläväPuu
31 posts in 1275 days
#2 posted 06-04-2015 04:58 PM
Thank you, and yes….it was a pleasure to finally have that positive reinforcement of having her mounted.
It irks me that I can’t complete the internal glazing bar work with wax until the rest of the leadwork has been done! Six panels to go….
View stefang's profile
stefang
15881 posts in 3329 days
#3 posted 06-04-2015 06:40 PM
Extremely well done and beautiful too.
