To download a measured drawing or to see the full photo gallery, click here:
http://www.eaglelakewoodworking.com/post/Super-Sled-Crosscut-and-Miter-Sled.aspx
Project Description:
I just completed a two part video series on how I made my new table saw sled. I’ve named the new sled the “Super Sled”.
The Super Sled combines two of my best shop jigs!
I love my original crosscut sled, so when the voters at Eagle Lake asked me to make a video about how to make that sled, I started to think of ways to improve upon the existing design.
I regularly use two different sleds in my shop:
1. My crosscut sled which I use mainly for crosscutting, and cutting shoulder cuts on tenons.
2. Wood Magazines Universal Tablesaw Jig which I use exclusively for mitering.
While contemplating ways to improve on the design of my crosscut sled, I started to focus on the concept of combining the two sleds. I spent a lot of time modeling the new Super Sled in Google Sketchup and I feel I have come up with one of the most versatile crosscut / mitering sleds around. When you see the video for the construction of the sled, I think you’ll be surprised at how easy it is to build for yourself!
Features:
Crosscutting
The Super Sled has all the benefits of my original crosscut sled, including a t-track for adjustable stop blocks. The new sled uses a flip stop, so you can keep the stop in the same place, but flip it up out of the way to make other cuts in between.
With generous capacity to the left and right of the saw blade, the Super Sled can handle just about any crosscut. The main fence is extended out farther on the left side of the blade allowing you to use the flip stop for long cuts.
Mitering
I really love mitering with Wood Magazines Universal Tablesaw jig which is why I wanted to incorporate all the features of this jig into the Super Sled. The Universal Tablesaw jig needs to be switched from one side of the blade to the other when doing complementary miters. With an identical setup on both sides of the blade, you can easily miter on either side of the blade.
The fence used for mitering has a t-track for mounting a stop block or hold downs and can be positioned any where from 0 to about 70 degrees.
Versatility
I designed the Super Sled with versatility in mind. The four slots in the main board of the fence function the same as t-tracks, and allow for the inclusion of stop blocks, the miter fence, and other add-on jigs like a tenon or box joint jig.
The main board for the super sled is 1/2 inch plywood. I went with 1/2 inch plywood so I wouldn’t loose very much blade height capacity. The four slots in the main board are 3/8 inch wide from the top, and have a 3/4 inch wide shallow recess in the bottom and will accomodate a standard 5/16 inch t-bolt.
-- John Nixon - Buffalo, NY - http://www.EagleLakeWoodworking.com
15 comments so far
TopamaxSurvivor
home | projects | blog
3000 posts in 568 days
posted 259 days ago
Thanks. I need to build one of these ;~)
davidroberts
240 posts in 378 days
posted 259 days ago
John, I just wanted to say I really like your work and your videos. I especially like that you get right down to business in the videos. They are full of helpful tips and are nicely produced. It seems some of the video’ers like to talk for 9 minutes then make a cut the last minute. I’ve even seen some that are just all talk. I appreciate that you stay focused and try to show as much actual work as possible. Keep up the good work!
-- david roberts, houston area, "A little knowledge is a dangerous thing, but that has never been a problem for me."
David
1982 posts in 1031 days
posted 259 days ago
John -
Another outstanding presentation from Eagle Lake Woodworking! I alway enjoy your attention to detail. I especially like your tips and workflow in the shop. After watching both videos I believe my shop will be seeing another crosscut sled in the future! I’m a huge fan. Thanks for sharing!
David
John Nixon
167 posts in 955 days
posted 259 days ago
Thanks Guys! I appreciate you checking out the video and commenting here.
I wanted to show an easy method for two of the things that most people seem to question when building a crosscut sled:
1.) How to get the runners on there and operating smoothly.
2.) How to square the fence to the blade.
There will be a another video in this series about how to build the accessories and use the sled.
David Roberts – I know what you mean about showing the woodworking action. I try to focus on showing as much closeup woodworking action as possible.
14915 posts in 743 days
posted 259 days ago
Great blog John. Very professional explanation.
TopamaxSurvivor
posted 258 days ago
John, I have watched your video a couple of times. The only question I have is how to best square up the back fence if you don’t have a planer and joiner?
John Nixon
posted 258 days ago
TopamaxSurvivor – without a jointer and planer, I would probably make a torsion box fence. Are you familiar with constructing torsion boxes? Essentially, it’s a grid that skinned on both sides with sheet material (plywood, hardboard, or mdf).
The option would be a lamination of two pieces of 3/4 plywood. If you have some decent plywood that’s flat, this would provide a suitable fence because plywood has a consistant thickness.
Do either of these sound good to you?
TopamaxSurvivor
posted 258 days ago
Thanks John, I’m not familiar with a torsion box fence. Going with the plywood option sounds easy enough.
TopamaxSurvivor
posted 258 days ago
John, another question, if you don’t mind. What are the runners made of and where do you find those plastic strips? BTW, Fantastic website you have ;-)
John Nixon
posted 258 days ago
TopamaxSurvivor -
I’m glad you like my site…thanks.
I’ve been meaning to put a parts source for this project at my site that will show where to get the things I had to buy.
The runners are UHMV plastic and are available from PeachTree and other places:
http://www.ptreeusa.com/uhmw_list.htm
The 48 inch strip is what I used and cut it into 26 and 22 inch runners.
John
cabinetmaster
8490 posts in 451 days
posted 258 days ago
The best home made sled I’ve seen. I need to build me one after I get a new tablesaw….....LOL
Don "Dances with Wood" Butler
275 posts in 288 days
posted 258 days ago
I use sleds to make almost EVERY cross cut I make on the tablesaw. Congratulations on a well designed sled!
By the way, I noticed you used a ShopSmith in the drillpress mode. I’ve had a SS for about 27 years. It was my first serious woodworking tool. In my opinion (you know what they say about opinions!) the SS is hard to beat as a drillpress. I don’t have another drillpress and I don’t intend to. The SS has good quill length for deep holes and great speed control in a stepless range.
Thanks for the first video. Looking forward to the second.
d
-- If a man says something in the forest and there's no woman to hear it, is he still wrong?
John Nixon
posted 258 days ago
Thanks Jerry!
Thanks donbee.
RE: Shopsmith – you nailed it, it’s a great drill press. In fact, I took mine off it’s stand and made a small-footprint dedicated stand so that I have it in drill press mode all the time. The Shopsmith I have is a 1951 10ER that belonged to my grandfather. I cherish that machine for it’s sentimental value and I’ll keep it forever. It still runs almost like new with the original motor and bearings, although I bet I am about due to change the quill bearings.
The second video is actually accessible from that same viewer up above, it’s just sort of cut off. Check out the upper right hand side of the player, you can see part of the thumbnail for part 2.
Thanks for watching and commenting here, I appreciate it
John
Beginningwoodworker
4102 posts in 565 days
posted 251 days ago
Nice video! I use a crosscut sled all the time on my table saw.
-- CJIII Future cabinetmaker
Mike
140 posts in 275 days
posted 58 days ago
Really nice, I like the sled idea. Thanks for the video.
-- Mike, VT
