Splash Chair
Blog entry by Dr_Unix posted 06-07-2008 02:16 AM 1159 reads 0 times favorited 0 comments Add to Favorites Watch
Talk about extreme curves, this design takes the cake!
Splash Chair
Even though it wasn’t built out of wood, it very well could have been. Fibeglass makes it lighter. Here’s how the chair was made:
“The chair was sculpted at 1/8th scale using Sculpey clay. From there, the model was cut into ¼ inch slices. These slices were scanned, blown up to full scale, and plotted to be used as a template for the full scale model. From there, the templates were adhered to 2 inch pink insulation foam, cut out, and assembled to the full scale form. Countless hours of sanding later, the form was coated in 4 coats of Elmer’s glue to protect the foam from resin. After the glue was dried, the form was sprayed with chopped fiberglass using a chopper gun. Once dried, the fiberglass was sanded down, then coated with Bondo. After sanding the Bondo as smooth as possible, it was painted with high epoxy glossy white paint.”
Read the full post on Yanko Design.
0 comments so far
