Myrtle Anniversary Shaker Table #18: So that's what it'll look like...
Blog entry by DoctorDan posted 02-27-2011 01:07 AM 1706 reads 0 times favorited 1 comment Add to Favorites Watch
« Part 17: Nearly somewhere to sit... Part 18 of Myrtle Anniversary Shaker Table series Part 19: Filling »
The Anniversary table has been a long time in the coming. To check proportions and decide on final sizing and shaping I assembled the piece in our small courtyard. The shaker inspired modern table is a 2×1m trestle table with two benches capable of sitting eight comfortably.
The benches will be assembled with long screws covered by ebony plugs – keeping the detail of the top.
In the shaker design which uses 3/4” timber (cf. 1 1/2” timber in my piece) there is a stretcher beneath the benches to prevent racking and increase strength. Although this is not needed with the thicker timber I plan to add a smaller stretcher for aesthetics.
The top I’ve had completed and finished for nearly 6 months. Given the heat we’ve had lately the top has shrunk about 1.5cm across it’s 1m width. The breadboards were designed for 2cm of movement so this isn’t a problem (other than needing to tidy the breadboards).
Since this last photo was taken I’ve shaped the stretcher supporting the two legs. In keeping with the rest of the piece. It now has a gentle curve thinning the mid section. The ends will be tightened with keyed m&t joints which need to be shaped and sanded.
Work in progress photos and details.
-- Daniel - http://theloveofwood.blogspot.com/
1 comment so far
View jeffbranch's profile
jeffbranch
110 posts in 2735 days
#1 posted 02-27-2011 04:51 PM
Beautiful work. I like the thick breadboard ends and the shape of the feet.
-- http://jeffbranch.wordpress.com
