Shaker Blanket Box #6: The Lids
Blog entry by DoctorDan posted 12-14-2010 10:32 AM 1497 reads 0 times favorited 1 comment Add to Favorites Watch
« Part 5: Base Mouldings Part 6 of Shaker Blanket Box series no next part
The solid pine lids for the two boxes is complete and ready for finishing. Two boards were matched for grain and rub glued together with titebond III. The pieces then cut to size with the circ saw and guide. The edges were than rabbetted first using the LN rabbet block plane and a offcut as a guide and then the LV plow plane. (The reason for this was the plow plane which lacks a knicker caused significant tear out when used across the grain, the plow plane was used to finished due to a faster action and depth stop.) The groove was cut quickly and easily with the plow plan. The middle 4” is glued with titebond three (to allow expansion). A LN hand saw was then used to trim the edges. The corners are curved with a saw and rasp. The edges a 1/8” CMT round over bit in a bosch trim router. The pieces are ready to final sanding.
-- Daniel - http://theloveofwood.blogspot.com/
1 comment so far
View degoose's profile
degoose
7227 posts in 3257 days
#1 posted 12-14-2010 11:11 AM
Looking good… will they be ready for Xmas?
