Shaker Blanket Box #3: Flattening the Sides
Blog entry by DoctorDan posted 11-18-2010 11:58 PM 1315 reads 0 times favorited 3 comments Add to Favorites Watch
« Part 2: Timber Purchase, Prep & Glueup Part 3 of Shaker Blanket Box series Part 4: Dovetail Dry Fit »
The timber in this project was purchased as ‘dressed-all-round’ (or DAR). This is meant to mean that each edge side is flat, parallel to the opposing side and square to the edge. For several reasons this is never the case. The timber is processed probably years ago in a production line in a climate different to my own. The changes to moisture content as it dries further allows wood to do it’s think and warp, cup and twist. Crosscutting the timber into smaller pieces changes the internal tensions within the board allowing new movement. And the mass produced aspect means that care is not taken with individual boards.
To begin with I tranverse (planing 90 degrees to the average grain direction) with my Stanley No 7. The blade (which is original) I have sharpened with a chamber (curve) to scoop the grain. Tranversing results in small areas of tear out.
The next step would be using a jointer or a smoother plane to make passes at 45 degrees and then parallel to the grain. The process needs constant checking with straight edges and winding sticks to make sure you’re still flat. But I don’t have a good smoother… so it’s back to the power tools.
Using a belt sander (Makita 9924DB) I first traverse and then move parallel to remove the plane marks.
Using a random orbit sander (Makita BO5021KX1) I then remove the belt sander marks.
In the end I have four boards 540mm x 860mm ready for joining.
This technique is not perfect, but it works. Hand planing to finish would be faster, more enjoyable, less dusty, and result in a better finish. (Though care must be taken for tear out.) However, you need a finely tuned smoother which I just don’t have. Did I mention there is a wish list on this site….
Sneak Peak: The Next Step – Dovetailing the Sides
The sliding leg vice comes into it’s own…
(Photos are not of the blanket chest, but rather the wax melter, technique is the same.)
-- Daniel - http://theloveofwood.blogspot.com/
3 comments so far
View NBeener's profile
NBeener
4816 posts in 3078 days
#1 posted 11-19-2010 12:29 AM
Beautiful work, and … an important lesson imparted.
I’ve never been able to just USE S2S or S4S, either—likely, for exactly the reasons you gave.
Which makes me feel that much better about the jointer and the planer that I bought, and confirms my notion that buying rough-sawn, or skip planed lumber—for less money—is a smart move.
-- -- Neil
27251 posts in 3726 days
#2 posted 11-19-2010 01:06 AM
This is an interesting blog, Daniel. I agree with Neil’s comment about buying rough lumber and processing it. When I used to buy S4S lumber it had much the same problems as you experienced.
View rayb444's profile
rayb444
5 posts in 1253 days
#3 posted 09-15-2014 05:00 PM
Really beautiful work.
