For Christmas this year I’m making 2 Blanket Boxes (Toy Chests for the kids) and a Wax Melter. The materials (radiata pine) and construction (dovetailed solid timber) is fairly similar so I’ve working on them together.
Step 1 – Purchasing the Timber
I purchased the timber (with an extra few boards) from Bunnings. Fortunately they must have had new stock in and the boards I selected were actually close to flat and without major defects or many knots.
Step 2 – The Rough Cut Battle Plan
After marking out all my cuts (with margin for error) I then rough cut the pieces using my Makita Jigsaw.
Step 3 – Jointing
The boards were close to flat from the shop. Although, I would normally still go through the processing of dressing the timber (jointing and thicknessing) this time I decided I would hand plane the faces after glue up and would use the machines to do the edges.
Step 4 – The Glue Up
With a new bottle of Titebond 3 I started gluing up the 16 pieces required for the projects.
-- Daniel - http://theloveofwood.blogspot.com/
2 comments so far
Scott R. Turner
home | projects | blog
181 posts in 1385 days
#1 posted 949 days ago
I’m surprised you can get good cuts with the jigsaw. Mine seem to rarely be straight and plumb.
DoctorDan
281 posts in 1212 days
#2 posted 949 days ago
I can get fairly straight and clean cut with the jigsaw. Cuts nice and smooth on these softer timbers with minimal vibration.
I only wanted a rough cut though. When the panels are glued up I’ll recut the edge with a circ saw. The jigsaw is quieter and safer and hence my preference for rough cuts.
THanks for the comment.
