Myrtle Anniversary Shaker Table #10: Shaker Bench Design
Blog entry by DoctorDan posted 08-08-2010 01:20 PM 3755 reads 0 times favorited 1 comment Add to Favorites Watch
« Part 9: Woe is me... Curved Legs Aren't Simple Part 10 of Myrtle Anniversary Shaker Table series Part 11: The Legs (Thanks for the Tip DenverDave) »
I’d like some feed back on some bench design modification. I’m attempting to remake this traditional shaker table and bench with back support. The design calls for a flat bench, parallel to the floor. I’ve sloped mine slightly (20mm over the 300mm width.) I’m also using thicker material 40mm cf. 16mm.
Any feedback will be welcome.
SketchUp Examples
http://sketchup.google.com/3dwarehouse/details?mid=15b3111c1611c2e5738e43095496b061&prevstart=0
http://sketchup.google.com/3dwarehouse/details?mid=f8d42c0e415ca0b738e43095496b061&prevstart=0
http://sketchup.google.com/3dwarehouse/details?mid=fe47a607ef75f2f9310af74324aae27f&prevstart=0
-- Daniel - http://theloveofwood.blogspot.com/
1 comment so far
View jlsmith5963's profile
jlsmith5963
297 posts in 3257 days
#1 posted 08-08-2010 08:32 PM
Daniel
Based on the way they lived the Shakers made sure their designs were light so they could be easily moved about (or lifted to be stored hung on the wall). Thus, physical lightness of form (which results in visual lightness) is an essential aspect of the Shaker aesthetic. Using thicker material will effect the ‘line’ of the form and the ease of it’s use (physically moving it). While you are certainly free to do as you wish, the thicker, heavier dimensions aren’t consistent with the Shakers notion of form and practicality.
-- criticism: the art of analyzing and evaluating the quality of an artistic work...
