Myrtle Anniversary Shaker Table #9: Woe is me... Curved Legs Aren't Simple
Blog entry by DoctorDan posted 08-07-2010 12:46 PM 1533 reads 0 times favorited 3 comments Add to Favorites Watch
« Part 8: Sneak Peak: The tabletop after a coat of oil... Part 9 of Myrtle Anniversary Shaker Table series Part 10: Shaker Bench Design »
Woe is me.
I can’t decide on the legs. The ideal plan would be to steam bend, or laminate the legs.
The short grain weakness is the problem…
If I laminate I don’t think I could to the tight curve of the foot and would need to attach a foot… which would be obvious.
If I steam bent and then laminate I could make all the curves… but I can’t think of a mould to do it…
It is possible to do all of this… but I only have 4 days to do it… no steaming gear…. and no success on the first mould…
At this rate… I may end up cutting it from straight grain solid timber… drilling up the leg and inserted an unglued steel rod… that’ll fix it… but it ain’t classy.
-- Daniel - http://theloveofwood.blogspot.com/
3 comments so far
View degoose's profile
degoose
7227 posts in 3230 days
#1 posted 08-07-2010 12:59 PM
Certainly a dilemma….
View sras's profile
sras
4699 posts in 3004 days
#2 posted 08-07-2010 02:40 PM
Nice design!
An idea would be to layer up thinner pieces with grain running at different directions. Maybe three layers. The two outer layers could be a thin slab with grain running horizontal as in your picture. The center layer could be much thicker and consist of two pieces meeting in the center – each running parallel to curve of the leg.
Just a thought.
View DenverDave's profile
DenverDave
41 posts in 2726 days
#3 posted 08-07-2010 08:12 PM
Looks like a beautiful table. How about making the curved piece out of two boards glued together in a “V” shape?
