The Hardware
Deciding on what type and which brand of vice to use was an ordeal in its self. I have to say I changed the design a number of times – eventually deciding on a leg, sliding leg, and tail vice. Then I had to decide on brand. Well… should I buy cheap carbatec $40 ones… or should I go traditional Big Wooden Vice style… but I couldn’t go past BenchCrafted. Two factors stood out… the precision build and the use of a wheel rather than a T bar which provides nice control and also speed.
I was a little disappointed, that after 2-3 weeks admiring my vices in my lounge room I notice significant rust. (Some metho, steel wool, and light machine oil and it was easy to fix.) I should also note that the BenchCrafted vices (plus postage to Australia) were by far the biggest expensive (3/4 the cost of the entire bench.)
Now having the hardware, I needed some wood.
The Legs
This part was easy. Final dimensions 142mm (5 1/2”) x 130mm (5 1/16”).
The Chops
The chops are made of 44mm blackbutt. After several sketches I came up with this design. The majority of the curves were produced by extensive Forster drilling. 1/8” round over was added to all components.
Some work in progress photos.
The Parallel Guides
A simple twist on classic roubo.
-- Daniel - http://theloveofwood.blogspot.com/
4 comments so far
Beginningwoodworker
home | projects | blog
13225 posts in 1844 days
#1 posted 1163 days ago
Nice progress.
-- CJIII Future cabinetmaker
559dustdesigns
627 posts in 1339 days
#2 posted 1163 days ago
Daniel, your detail designs are very classy, two thumbs up.
-- Aaron - central California "If you haven't got the time to do it right, when will you find the time to do it over?"
ratchet
1192 posts in 1958 days
#3 posted 1163 days ago
Sweet! Your bench with those wheels is going to have that “extreme technical functionality” look to it.
Thanks for posting.
JustinB
10 posts in 1202 days
#4 posted 1163 days ago
Those vices are going to be great. I can’t wait to see how this whole bench turns out, especially the sliding leg vice.
