-- Until you spread your wings, you'll have no idea how far you can walk.
| Blog entry by DaveR | posted 300 days ago | 447 reads | 1 time favorited | 12 comments | ![]() |
Wixey 8'' Digital Protractor | Makita Makita Recon LCT203W 10.8 Volt Lithium Ion Impact Driver 2 Pc Kit |
| Latest Projects | Latest Blog Entries | Latest Forum Topics
12 comments so far
mics_54
home | projects | blog
432 posts in 370 days
posted 300 days ago
elegant. You would have to clone the pieces for that top though.
-- Dan, Sterling Alaska, http://sullcon.homestead.com/ Before you criticise some one, walk a mile in their shoes...then you will be a mile away and you have their shoes!
DaveR
1527 posts in 619 days
posted 300 days ago
Ya think? ;) Components.
Thank you.
bentlyj
794 posts in 369 days
posted 300 days ago
Well I came close. Still need work on the edges and I don’t know how to change the grain direction of the wood.
DaveR
posted 300 days ago
Good work Bently.
I drew 1/8th of the table top and made it a component. This was copied around the center point using the Copy/Rotate function. (Ctrl+Rotate, Option+Rotate on Mac) Then I opened one component and applied the material. I aligned the material on the flat surfaces by right clicking on the top face, choosing Texture>Position and then rotating the texture with the green handle.
bentlyj
posted 300 days ago
Thanks, I will give the Texture>Position a try. I drew the octagon and then did one detail, then copied and rotated to each side, For the edge I drew a curve and used the follow me to wrap the outside edge.
Components, hmmmm…..next time I will try a componant. :)
Oh yeah, after I drew the octagon I used the push/pull to make it 3/4” thick.
DaveR
posted 300 days ago
Bently, I made the rounded edge as a second component. Just for fun, I checked the file size without materials. As component instances it is 103 Kb. With the components exploded so its all one lump of geometry, it’s 805 Kb.
bentlyj
posted 300 days ago
Here’s try #2
Got the grain better. Over did it with the scalloped edges though.
DaveR
posted 299 days ago
Good, good. It looks like you chose a better material, too.
bentlyj
posted 297 days ago
I gave it my best Dave.
I couldn’t find the texture you used for the cushion, ( good thing ) I would never have gotten it to wrap the edges the way you did anyway. :-)
DaveR
posted 296 days ago
Very nice work there, Bently. I don’t remember where I found the material for the seat. It’s supposed to represent a seat woven of Danish cord. Yours looks good too.
FWIW that bench is based on Mark Edmundson’s Modern Bench FWW#194
mics_54
posted 296 days ago
I meant on the real top. The wood grain matches on all the sections and would make the piece beautiful but I don’t know how one would actually do that.
DaveR
posted 296 days ago
Photo image on laminate. LOL
