I wrote this elsewhere but I hope it might be useful here. Maybe someone will get something out of this anyway.
Important: I should have added this earlier. Before you start this tutorial, make the following setting changes. I’m assuming you haven’t already modified the starting template.
Under Window>Model Info>Units, Set Units to Fractional, change Precision to 1/64” and uncheck Enable Length Snapping.
Under Window>Styles>Edit, click on the wire frame cube and uncheck Profiles.
So, we’ll start with a couple of guidelines drawn up from the red and green axes. I’m making a tall, skinny table so I set them at 30”. Use the Tape Measure tool to do this and pay attention to the color of the trailing line as you drag. It needs to be blue. Click on the axis line, drag upward and type 30 followed by the Enter key.
Next get the Rectangle tool. Click on the intersection of the two guidelines and drag out between them. Stop dragging and type 24,24 followed by the Enter key.
Get the Push/Pull tool and push down on the face. Type .75 followed by the Enter key. You could also type 3/4 if you wish.
Get the Select tool (Arrow) and triple click on the flat box you’ve just made. This will select all of the geometry. Right click on it and choose Make Component. Give it an appropriate name and hit Create.
Go to the Edit menu and hit Delete Guides. I have a shortcut setup for that one so I only have to hit a single key to delete all the guidelines and points.
Orbit down low so you are looking up at the underside of the table top. TO make locating the legs easier, I put in some guidelines one inch from each edge. Get the Tape Measure tool, click on the edges one at a time and drag inward. Type 1 followed by the Enter key to place the lines one inch in.
Then get the rectangle tool and, starting at the intersection of two guidelines, drag a rectangle in toward the center of the table. Type 1.5,1.5 Enter. Get the Push/Pull tool and start pulling the face downward.
Type 29.25 Enter to set the length of the leg. Get the Select tool, triple click on the leg geometry to select it all, right click on it, choose Make Component, give it a name and click Create.
So now we have the top and the first leg drawn. They are each components so although they reside in contact with each other, they don’t modify or glue themselves to the other. There are other benefits to making them components which we’ll see shortly. It’s good practice to get in the habit of making components of the parts you’d have to make in the shop if you were cutting wood.
I suppose we ought to have a few more legs so our table will stand up. We could draw each of the others but that’s kind of a waste of time and energy. How about we just copy the leg we drew instead?
With the leg selected (it should still be selected after you made it a component) get the Move tool. Hit Ctrl to invoke the copy function. Grab the leg at the top corner. This is the corner that will correspond to the intersection of the guidelines, in this case to the left.
Start dragging the cursor along the guideline toward the left. You’ll see a copy of the leg has been created and it is following the cursor. When you get close to the intersection of the guidelines the tool should snap into place.
Now, while that new leg is still selected, right click on it and choose Flip. Select the axis to flip along that is parallel to the direction you just moved the leg. In my case I worked along the red axis so I chose Flip Along Componenet’s Red Axis. If you aren’t certain about the axis to flip along, orbit so you can see the global axes.
The second leg won’t look any different at this point but that’s fine. This last step will pay off later.
Next, get the Select tool. While holding Ctrl, select both legs. Get the Move tool and invoke Copy again with Ctrl. Grab one of the leg components by a corner that will correspond to the intersection of another pair of guidelines for the opposite side of the table. Move to copies to that side.
With the two newest legs selected, right click and choose Flip again. This time you’ll flip along the other horizontal axis. I flipped along red the first time so green will be the choice this time.
Now we’ve got a four-legged table. kind of spindly looking but at least we can tell what it is supposed to be. Nobody would mistake it for a tire swing, anyway.
Now we’ll taper the legs which is going to demonstrate a benefit of making the legs instances of the same component and flipping the copies as we went along.
Orbit and zoom so you are looking up underneath the table at the top of one leg. It makes no difference which leg.
Get the Tape Measure tool and set a guideline on an inside face of a leg 3” down from the top. Then double click on the leg component with the Select tool or right click and choose Edit Component. Get the Line tool (Pencil) and trace along the guideline from outside edge to inside edge. Watch for the colored trailing line. In my example it’s green which confirms I’m drawing parallel to the green axis.
Once you get to the edge, turn the corner and draw another line to the other outside edge. It should show as red if your first one was green.
These lines define the ends of the tapers—we’re only tapering the legs on their two inside faces—and they will act as fold lines for the next step.
With those two lines drawn, move your view down to look at the bottom of the leg. Set a couple of guidelines in 1” from the outside edges. the intersection of these lines will be our snap to point for the Scale tool. Double click on the bottom face of the leg. A double click will select the face and its bounding edges.
Click on the Scale tool. You’ll see some green scale handles surrounding the selected face. Click on the one at the inside corner and drag it to the intersection of the guidelines.
Instead of placing the guidelines, we could figure out a scale factor which in this case wouldn’t be so hard but in the shop we wouldn’t think about the taper that way. We’d think, “Let’s taper the leg to one inch square” or “Let’s take a half inch off each of the inside faces” or something like that. No need to bother with the math here.
Now when we zoom back to look at the whole table, we see that all four legs are tapered and the tapers are on the proper sides of the legs. The taper may be difficult to see in this view but notice where the fold lines are.
Now lets add the aprons. Orbit around so you are looking down on the table. Select the top with a single click and right click on it. choose Hide.
Zoom in close on the top of a leg. Drag a guideline in 1/4” from the front edge. Get the rectangle tool and drag a rectangle down the inside face of the leg. Start at the intersection of the guideline and the top edge of the leg and go down toward the fold line on the leg. Make the rectangle 3” high and 3/4” wide. Look at the Measurements box (VCB in SU6) to check to see what order you’ll need to enter the values.
Get Push/Pull and pull the apron out to the opposite leg. Zoom as needed to be able to do this.
Get the Select tool and triple click on the apron. Right click and choose Make Component. Give it a name and hit Create.
Move over to the opposite side of the table and put in another guideline a 1/4” in from the outside edge of a leg. Then copy the apron using Ctrl+Move. Remember to grab the apron at the corner that will correspond at the end of the move to the intersection of the guideline and to edge of the leg. Then flip the new apron component.
Now, since this is a square table, we’re going to use a neat trick for the other two aprons.
First get the Tape Measure tool and draw a guideline between diagonal corners on the top of one of the legs. repeat that on another leg so that you have two guidelines crossing in the center of the table.
Select both apron components and get the Rotate tool. Hit Ctrl to invoke the copy function. Place the Rotate tool on the intersection of the diagonal lines, click once to set the center of rotation, click again along one of the diagonals and then drag around to copy/rotate the aprons. Type 90 followed by the Enter key.
Unhide the top. Go to the Edit menu and click on Unhide>All and then delete all the guidelines.
In the next installment we’ll add some details to the aprons and start on the joinery.
-- Quantum materiae materietur marmota monax si marmota monax materiam possit materiari?
19 comments so far
Mario
home | projects | blog
824 posts in 803 days
posted 177 days ago
Thank you for posting this step by step plan. I actually did it.
Thank you.
-- Hope Never fails
DaveR
1045 posts in 472 days
posted 177 days ago
Mario, I’m glad to know it helped.
I think I’ll replace the images with some larger ones when I get home from work. Might make it easier to see things.
Mark Shymanski
1259 posts in 464 days
posted 177 days ago
Great step by step process! Thank you. I look forward to the joinery session.
pommy
522 posts in 443 days
posted 177 days ago
Hi Dave its always good to see someone’s view on sketchup have you seen betsy’s blog’s on sketckup
andy
-- cut it saw it scrap it
Betsy
2291 posts in 647 days
posted 176 days ago
Dave—now I get tapering!!!!
Andy——Dave was the reason I could do the blog. He helped me through the whole process. Dave runs a blog and teaches SU classes. I am glad to know you saw my blog though!
-- My digits count!
Rustic
869 posts in 348 days
posted 176 days ago
Thanks Dave
-- There is no such thing as a mistake. Its called a design modification Rick Kruse, Grand Rapids, MI
DaveR
posted 176 days ago
I’m glad this is helping some of you.
Betsy, I’m glad that adding the taper made sense. There are actually several ways to get that taper but this is dead easy once you see it.
DaveR
posted 176 days ago
Dave T
56 posts in 371 days
posted 169 days ago
Dave, thanks for the step by step. A couple of neat tricks and shortcuts I didn’t realize were in there. I had made a couple of decent models before, but as I was trying more complex drawing methods gave up on it because I didn’t want to put the time in to learn. This had renewed my interest. I will have to go through the tutorials again for things I may have missed.
Again Thanks!
Rxmpo
111 posts in 497 days
posted 167 days ago
Dave, this has been a great tutorial. Thank you!!!
I have been struggling with one thing and I cannot figure it out.
“Draw a guideline between diagonal corners on the top of pone of the legs”, for the life of me, I have not been able to get the tape measure tool to give me the diagonal guide lines. I have clicked one corner and dragged the line across to the other corner while…holding the cntl key, w/out the cntl key, while in edit component, while not in edit component… Not sure what I am doing wrong? I know this is not a major issue, but if I understand what I’m doing wrong I’m sure I won’t break my mouse in frustration:)
Thanks again,
Mike
DaveR
posted 167 days ago
Mike, thank you.
Have you tried drawing the diagonal guideline by clciking on diagonally opposite corners of a single leg? You shouldn’t need to hit ctrl or anything.
Rxmpo
posted 167 days ago
Dave,
Ok,....I’m not sure if I was using the correct tool, but I used the pencil tool not the tape measure to draw a line between the diagonal points and it worked? The picture in the blog looks like the tape measure guide? Well, not sure if this is a good alternative or not, but I’m thankful that I finally got it to match your finished desk. Whew.
(Edited: Dave, just realized SINGLE LEG in your post. Thank you…that was the problem, but I guess the pencil will work too. Thanks.)
Mike
DaveR
posted 167 days ago
Mike, I’m glad you got it to work. The Line tool (pencil) would work for locating the center, too. The reason I would choose the Tape Measure tool, which I did use for this, is that I can quickly delete the guidelines with a single keystroke. Lines drawn with the Pencil tool take more time to get rid of.
Dave
Zuki
1180 posts in 829 days
posted 167 days ago
Tks Dave. I just completed the table. I too had a problem with the tape measure on the diagonal but substituted with the line tool. I liked the taper and the rotate thingie.
Now of to part 2.
kolwdwrkr
1554 posts in 342 days
posted 152 days ago
Hey Dave, I tried the table and failed. I got to the legs and the taper. I tapered the legs and had them flipped the wrong way. Is there a way to rotate the legs individually or are you stuck once you make them a component? I could have fixed it easily if I could have rotated them. Anyhow I got bored of it and will need to try again later. Thanks for posting this. It isn’t as easy as it looks, at least to us computer illiterate folks.
DaveR
posted 152 days ago
You aren’t stuck once you flip the components. You can use Undo and back up. Rotating the legs would work for this table but there are a lot of similar applications where rotating the copies of the original wouldn’t be appropriate.
If you’d like, send me your SKP model so I can see what you’re getting stuck on. I’ll PM you.
Dave
Eric
27 posts in 151 days
posted 148 days ago
Thanks Dave. This was helpful to learn some new tricks. I too gave up on diagonal guides and used lines before you mentioned just using one leg.
-- ED
DougK
8 posts in 135 days
posted 134 days ago
Thanks Dave. I took your advice and went to your blogs and loved this first one. Great help to us beginners. You’ve been a great help today.
Doug
thelt
110 posts in 131 days
posted 23 days ago
Took me a couple of trys at the moving parts, but I did it. Thanks Dave.
-- There are three signs of old age. The first is loss of memory. I forgot the other two!
