Draw the padded portion of the headboard complete with buttons.
-- Until you spread your wings, you'll have no idea how far you can walk.
| Blog entry by DaveR | posted 103 days ago | 495 reads | 0 times favorited | 32 comments | ![]() |
| Latest Projects | Latest Blog Entries | Latest Forum Topics
32 comments so far
tooldad
home | projects | blog
454 posts in 608 days
posted 103 days ago
impressive, I need to get to work on that tutorial I was talking about earlier. I have the help site bookmarked and was going to get the videos downloaded. Again Any suggestions? Thanks, Jason
Joe Lyddon
481 posts in 945 days
posted 103 days ago
With all those curved lines, shading, etc., no thank you… That is well beyond my skill level!
I didn’t think you could even DO that!
... but, when you’re a true expert at something, I guess you can do ANYTHING!
Very nice Dave.
3035 posts in 914 days
posted 103 days ago
Oh, shoot! I’m useless and now everyone will know!
bluchz
142 posts in 266 days
posted 103 days ago
Does Sketch-up have an Array command similar to Autocad?
DaveR
1517 posts in 613 days
posted 103 days ago
“Does Sketch-up have an Array command similar to Autocad?”
Yes.
Jason, let’s talk.
Joe, even if you just muddle through like I do, it can be done. Thank you for the compliment.
Bob#2, I didn’t think and still don’t think you’re useless.
bentlyj
783 posts in 363 days
posted 103 days ago
I’ve tried criss crossing curves…..filling in faces…..pushing and pulling curved shapes…..pulling buttons down….well let’s say I’ve tried a lot of wrong ways. I’m going to have to wait for the tutorial but am still trying things. :)
bentlyj
posted 103 days ago
WELL….......still needs some work,
DaveR
posted 102 days ago
Not bad Bently. How did you do it?
I did it this way.
Joe Lyddon
posted 102 days ago
I figured you would be using arcs someway… You attacjed it in a very logical manner, as usual.
Thank you for the description! COOL method… Is that Soap Bubble routine readily available? At what cost?
DaveR
posted 102 days ago
Joe, thank you. The Soap Skin Bubble plugin is free. I liked to it at the beginning of the blog entry.
bentlyj
posted 102 days ago
Thanks Dave,
If I remember right, (I tried a lot of stuff first),
I drew the square, then I drew an arc on 2 sides, selected one of the arcs and used the follow me tool on the other. I then copied it for the rest of the squares. I couldn’t figure how to make the outside row flat around the edges. I drew the buttons and just placed them in the corners.
Don "Dances with Wood" Butler
275 posts in 288 days
posted 102 days ago
I guess I’m a little spaced out today.
I downloaded the bubblemaker, but I think I put it in the wrong folder.
The (rather confusing) directions on the website seemed to be saying the files go in the tools folder.
That’s where I put ‘em.
Then I extracted them.
But, whaere do I go from there?
It isn’t working at this point.
-- If a man says something in the forest and there's no woman to hear it, is he still wrong?
DaveR
posted 102 days ago
Hi Don,
Sorry. I never looked at the instructions on the website. The files should be extracted into the Plugins folder. Then reopen SU and check that all of the boxes are checked under window>Preferences>Extensions. You may need to turn the toolbar on under View>Toolbars.
DaveR
posted 102 days ago
Bently, that’s not bad. Not bad at all.
bentlyj
posted 102 days ago
Hi Dave, thanks,
I went back and tried again. This is how I made the one square that I duplicated for the rest.
I haven’t tried downloading the plug in yet. I looked at your tutorial with the plug in, now I can understand how you did the corners and ends. I’ll have to give it a shot when I get the chance.
Hope you can follow this OK.
DaveR
posted 102 days ago
Bently, that’s a neat method of creating a dome. You could skip the Push/Pull step though. Your second to the last step illustrates a thing to be aware of with Follow Me. The ends of the extruded shape end up perpendicular to the segments at the beginning and end of the path. If you don’t want them to be that way, you need to run the cutting plane through.
Good work.
posted 101 days ago
Dave,
I’m exasperated.
I’ve deleted the ruby and downloaded it again, this time to the plugins folder.
Then I extracted the contents of the zip file to the plugins folder.
I made sure the extensions are enabled in preferences.
Nothing.
It just appear in SU.
Please set me straight.
I did something wrong, but I don’t know what!
d
DaveR
posted 101 days ago
Don, you should have a file called SoapSkinBubbleTools.rb and a folder with the contents shown here:
Do you have both of those?
posted 101 days ago
Ah!
I guess I wasn’t paying attention when extracting.
I have it now, and thanks very much.
d
DaveR
posted 101 days ago
You’re very welcome, my friend. Enjoy playing with the plugin.
bentlyj
posted 101 days ago
Dave, your right,
you don’t need to do the push/pull step. I don’t know why but when I was trying it that way the first time it wasn’t working. Maybe I was doing something different. It was leaving the surface flat instead of domed.
I enjoy your challenges and learn things on every one, thanks for doing them.
stefang
1645 posts in 227 days
posted 88 days ago
Great idea about the challenges Dave and super for those who want to learn. I am probably just going to continue on the caveman level for now though because I’m using so much time on LJ that if I get more involved in Sketchup I’ll never read any books or ever get into the shop, even though I’m retired. I guess the world is just getting too fast for me. Keep up the good work, I’m sure a lot of people are benefiting from it and appreciate your efforts.
-- Mike, American in Norway
spaids
458 posts in 586 days
posted 60 days ago
I did it the hard way first then I installed soap bubble. It seemed to work but then after playing with it a bit it crashed sketchup.
-- Wipe the blood stains from your blade before coming in.
DaveR
posted 60 days ago
Waid, do you have the current version of SketchUp? The new version was released yesterday.
bentlyj
posted 60 days ago
Hi Dave,
When you download the new version will it go right over the old?
DaveR
posted 60 days ago
Hi Bently. Yes, you can just download over the old so you won’t lose any plugins or styles or components you might have installed.
bentlyj
posted 60 days ago
Thank You Dave!!
DaveR
posted 60 days ago
’s alright. ;)
bentlyj
posted 60 days ago
Hey Dave, From what I could find it looks like the sketchup 7.1 is only a free upgrade for sketchup pro users.
Is it available for us freebie guys using the regular sketchup 7??
DaveR
posted 60 days ago
Bently, yes, free version also goes to 7.1. Go to this page and click on Download Google SketchUp 7
spaids
posted 59 days ago
Yea Dave I’m on 7.1. Maybe I was pushing this machine to hard. I was trying to do some soap bubbles on more complex shapes.
On a side note. When you soften the edges of the grid, is there a fast way to do that or do you just have to open the group and shift-erase all the lines?
DaveR
posted 59 days ago
Waid, you can open the group and then select all of its geometry by triple clicking on it someplace. then right click and choose Soften/Smooth from the Context menu. Before copying the groups to make the rest of the padding, convert them to components. This will help control file size. To convert the groups, sright click on the closed group and choose Make Component. If you want to give the component a definition name, go to the Entity Info box and edit the Definition there.
