quartersawn oak box dyed and stained new brass hasps 1 12 2014 #1: first set of photos showing unstained and stained box
Blog entry by Dan'um Style posted 01-13-2014 03:59 AM 2458 reads 1 time favorited 10 comments Add to Favorites Watch
no previous part Part 1 of quartersawn oak box dyed and stained new brass hasps 1 12 2014 series Part 2: shellac and dark brown Briwax »
Hasps on Ebay Hasps are cast alloy with a antiqued brass patina. Very good quality
Shipped direct from from China and the price was awesome.
MLK Cherry splines.
Quartersawn white oak box body, resawn to about 9/16.
Hasp screws are nicely patina-ted … 1/16 drill bit and worked perfectly.
Quartersawn white on top came from Frank Miller Lumber. I have a few boards left. Found a board with the grain I wanted for a fancy top. Cut the center out of the board. It was a 6/4 board and pieces are resawn 3/8
hand rubbed Dark Oak Alcohol Dye and Minwax Cherry stained
Approx 1/8 ” Chamfers on the top panels were all hand beveled with my 6×80 edge sander …. 40 grit, very quick .
Whats up next.
Box will dry and then 0000 steel wool to smooth all the fuzz and then the top coats. Lacquer to seal, Button shellac then brown wax on the outside. Debating on green felt. Maybe red this time. Thinking about a mirror in the lid (I have several small ones in a drawer) Will make a cool collectors box
10 comments so far
View lew's profile
lew
12062 posts in 3756 days
#1 posted 01-13-2014 04:27 AM
Dan, you certainly can transform that white oak into a beautiful piece!
View Handtooler's profile (online now)
Handtooler
1554 posts in 2133 days
#2 posted 01-13-2014 05:25 AM
Marvelous build! Thanks for sharing all the pics, great coverage.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View sras's profile
sras
4799 posts in 3130 days
#3 posted 01-13-2014 05:42 AM
You have a first class eye for color and texture. Always a treat to see your work!
View oldnovice's profile
oldnovice
6855 posts in 3368 days
#4 posted 01-13-2014 05:48 AM
WOW, Dan that is some good looking work!
View redryder's profile
redryder
2393 posts in 3102 days
#5 posted 01-13-2014 06:02 AM
Bitchin’ good….............
-- mike...............
View cajunpen's profile
cajunpen
14575 posts in 4066 days
#6 posted 01-13-2014 05:09 PM
Another great looking box Dan – I really like the “Campaign” style of box. I’d go with the red velvet interior on this one.
23928 posts in 3851 days
#7 posted 01-13-2014 10:50 PM
Nicely done Buddy.
View madts's profile
madts
1862 posts in 2340 days
#8 posted 01-13-2014 11:33 PM
Cool box man.
-- Thor and Odin are still the greatest of Gods.
View Bigrock's profile
Bigrock
292 posts in 2963 days
#9 posted 01-14-2014 01:04 AM
Hi Dan:
I hope this will help you to get a greater looking piece. So far it looks great and I like your hardware.
On pours woods (QSWO) it is not a good idea to use steel wool.
One- It gets left in the pours part of the wood and the acid that’s in Oak will cause rust spots in the finish.
Two- Because the surface is not smooth I would use a very fine grit (600 – 1000) sandpaper or a very fine soft sanding pad.
Don’t ask how I know, but I had to strip and refinish a project.
View Dan'um Style's profile
Dan'um Style
14172 posts in 3983 days
#10 posted 01-14-2014 03:01 AM
I said steel wool … but what I really meant to say scotch bright.
However steel wool has been used for many many of my projects. I mainly used it for rubbing paste wax, but also with oil finish. Prolly over a thousand times.
