Queen Bed #2: Finishing the Legs and fixing mistakes
Blog entry by ChunkyC posted 02-25-2012 11:13 PM 8836 reads 0 times favorited 2 comments Add to Favorites Watch
« Part 1: Getting Started, the legs Part 2 of Queen Bed series no next part
I finally have all of the mortises cut in the legs and the bed rail fasteners installed.
Next step, cut the tappers in the rear legs:
Now cut the tappers on the front legs: Oops, I misread the combination square AGAIN! The mortises for the bed rail fasteners are supposed to be 7-1/4” up from the bottom. I just have to remember to read the correct side of the square. So the mortises ended up being way to low.
I could make new legs but that would require a trip to the hardwood dealer and recutting all of those mortises, or attempt a patch. I opted for a patch. I believe it’s called a Dutchman but I could be wrong. If the Dutchmans don’t come out all that great, I can always remake new legs.
So I used my POS trim router to make a even mortise where the misplaced rail fasteners was:
Then I cut out a piece out of the same wood, used hand planes to get it to the correct size and then hammered it home:
I’ll see what it looks like after I cut the tappers in the front legs. If the Dutchmans look like crap, I’ll just make new legs…
-- Chunk's Workshop pictures:
2 comments so far
View Roger's profile
20916 posts in 2733 days
#1 posted 02-26-2012 01:19 AM
a hell-of-a-nice fix. wow looks good to me
-- Roger from KY. Work/Play/Travel Safe. Keep your dust collector fed.
View ChunkyC's profile
856 posts in 3183 days
#2 posted 02-26-2012 03:35 AM
Thanks Roger. The picture makes it look a lot better then it really is.
The leg is tapered on the bottom and the taper gets into the Dutchman about 1”. It sticks out like a sour thumb on the taper. The good thing is that it wont be easily seen as it’s on the inside.
