Fighting Dust #13: DIY Blast Gates pt 3 - Dimensions
Blog entry by ChunkyC posted 01-21-2012 08:42 PM 5930 reads 1 time favorited 4 comments Add to Favorites Watch
« Part 12: DIY Blast Gates pt 2 Part 13 of Fighting Dust series no next part
Here are the dimensions of the gates that I built.
Bodies:
7-3/4” x 7-3/4” x 1/2 Birch Ply
Gates:
3/16 Hardboard cut to fit the opening.
Spacers:
7-3/4” x 1” x 1/4” Hard Board. The 1/4” HB that I have access to is the stuff that is smooth on one side and has a rough texture on the other. I used a hand plane to reduce the thickness a little on the “rough” side.
Holes:
Cut to fit the diameter of the pipe that you’re using. I used a wing cutter on the drill press to cut the holes.
Pipe: (use what fits your system. This is what fit mine)
4” S&D Coupling cut in half (one half per gate.)
“Large” tin soup can. (Mine happened to be a can of fruit cocktail.)
3” DWV coupling. (This was a very tight fit with the hose. Hose had to be heated to install.)
4” Plastic Dust Collection Coupling
Glue:
Poly Urethane Glue to glue the Pipe to the body. Spray a light mist of water on the body and put the glue on the pipe. PUG needs water to cure and the water acts a “kicker” to speed up the process a little.
Yellow Glue to glue the spaces to the bodies.
Generally these gates are larger than they need to be. I would think that you could narrow them up quite a bit if you need the extra room. They can be made smaller and still work just fine. I had to cut one gate down on the back side so that It would fit between the wall and the riser pipe. It still seals just fine.
Ok I’m done with blast gates, promise. lol
c
-- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135
4 comments so far
View DIYaholic's profile
DIYaholic
19536 posts in 2579 days
#1 posted 01-21-2012 08:52 PM
Done blogging perhaps, not making & using, I would think.
What if I don’t like fuit cocktail?
Seriously though, EXCELLENT job and thanks for taking the time & effot to do so!!!
View ChunkyC's profile
ChunkyC
856 posts in 3159 days
#2 posted 01-21-2012 09:02 PM
That’s what I meant! I’m sure a lot of people are already tired of the blogs. What is it 4 blogs on blast gates now?
I’m happy to share my experiences and answer q’s that you might have though.
c
View Tennwood's profile
Tennwood
111 posts in 3086 days
#3 posted 01-22-2012 03:48 AM
Just discovered your blast gate blogs. Neat idea. Do you have any problems with duct and chips getting in the corners keeping the gates from fully closing? That is the biggest issue I have with the plastic and metal gates. I like how you attached them to the S&D pipes, another issue I have with the plastic fittings.
-- Jim, SE Tennessee, "Don't spare the kindling Dear, we have plenty"
ChunkyC
#4 posted 01-22-2012 03:53 AM
Phil: Yeah, no back. As I said, they are “pass through” style blast gates.
