Fighting Dust #4: I was inspired
Blog entry by ChunkyC posted 02-22-2011 03:56 AM 1376 reads 0 times favorited 5 comments Add to Favorites Watch
« Part 3: Tablesaw Overhead Dust Collection part #2 Part 4 of Fighting Dust series Part 5: One step forward ... »
Well maybe motivation instead of inspiration is more accurate. I took a could days of much need vacation and I spent today tinkering in the shop all day and reading LJ. I got to Neil’s blog, NBeener, and re-read his stove-pipe mod for his HF DC. It motivated me to start sealing some of my leaks. I said some!
I sealed all around the dust collector using foil tape after wiping it down with a rag and mineral spirits.
The secrete is to use small pieces and just do small areas at a time. I used pieces about 7-9” long. If you, read as ME, cut too long of pieces of that foil tape, it gets a bit unruly and hard to work with.
I also started sealing around the blast gates. Those plastic blast gates leak like a sieve! There’s on so much that I can do with them but ever little bit helps.
I did seal a couple of the PVC joints too with the foil tape but the PVC joints should be good. I put them together with silicone caulking. You can see where it squeezed out in the picture above.
Thanks Neil for the inspiration!
-- Chunk's Workshop pictures: http://spadfest.rcspads.com/thumbnails.php?album=135
5 comments so far
View dbhost's profile
dbhost
5686 posts in 3138 days
#1 posted 02-22-2011 04:33 AM
I need to get after sealing up the impeller housing on my HF DC… It leaks where the halves are joined… Not so much at the output side of it…
-- My workshop blog can be found at http://daves-workshop.blogspot.com, YouTube Channel https://www.youtube.com/channel/UCoa-AgyeFWqnQfGIJwdzkog
View Don's profile
Don
517 posts in 2979 days
#2 posted 02-22-2011 04:58 AM
Great blog Chunky! My own DC is in serious need of an overhaul and this blog may be a lot of help.
-- Don - I wood work if I could. Redmond WA.
View HokieMojo's profile
HokieMojo
2104 posts in 3634 days
#3 posted 02-22-2011 05:30 AM
Do the HF units really leak that much air from the housing?
View ChunkyC's profile
ChunkyC
856 posts in 3160 days
#4 posted 02-22-2011 05:42 AM
I don’t think so but an once of prevention… Mine is definitely leaking some where. The collector is not that easy to get out of the hole it’s in so I just sealed every joint while I had it out. I even found a hole in the 5” hose where a brad nail was sticking through it. lol
View NBeener's profile
NBeener
4816 posts in 3080 days
#5 posted 02-22-2011 06:31 AM
It starts with thanks for the inspiration.
But … very soon … it’s more like “Beener What have you got me hooked on ?” ;-)
My gut tells me the stovepipe mod made the biggest bang-for-the-buck difference (other than the change to the Wynn 35 filter, that is).
HokieMojo: My guess is … no—not much. But a roll of the foil metallic duct tape is about $9 … and would do about 30 of these, so … it’s virtually zero cost, and may provide some benefit.
I think it IS just a good practice to minimize leakage wherever you can.
-- -- Neil
