I bounced out of bed Saturday morning eager to make some more progress on the table. I went down to the shop and inspected what I had glued up the night before. Everything looked good so I went ahead and glued the end sections together with the long side aprons. I also installed the corner braces which I made from a piece of white oak I had laying around.
I pinned the tenons with 3/8” oak dowels and sanded flush.
Feeling pretty good about the progress, I started the milling process for the table top. I had two beams that were about 4×9”. First I trimmed a half inch off the long side so that I had a piece 8” wide as I only have an 8” jointer.
Next, I jointed one face then squared up the adjacent side so I would have a flat faces to run against the bandsaw fence and table.
When I built my router table, I made a large subsantial fence that I can set on the bandsaw and use for resawing. I had just bought a 3/4” 3 tpi Timberwolf resaw blade and was eager to see how it performed.
That new blade pretty much cut like a hot butter knife on the first three passes. Then on the last cut, about 1/3 of the way through, cutting all of a sudden became difficult and the blade began to wander. I thought the kerf was just full, but after completing the cut, and looking at it, it became apparent that my new bandsaw blade became a $42 nail finder. Duh..ohhh…...............what valuable lessons we learn on a daily basis. You see, I’ve got a brand new Lumber Wizard and in my hurry had not used it on the last beam.
If you look closely, you can see the ripples in the cut. I thiink I’ve got enough material left at the deepest cut to still mill up the top, but I was dead in the water without a sharp blade. I called Lumber Lady and she still had a new blade in stock and was even so gracious as to leave it out on the loading dock as I couldn’t get there before closing time and of course they aren’t open on Sunday. Even so, I’ll have to hunt up some more stock as what I thought was enough wasn’t. So, I guess I’m dead in the water till Monday. Argh…....!
At any rate, I got four pretty nice boards out of it, the only problem is I need to more to have enough and beams like this are scarce. I may have to go with three narrower ones before this is done.
Stay tuned, the saga continues…...............
-- Carl Rast, Pelion, SC
7 comments so far
home | projects | blog
16695 posts in 470 days
posted 169 days ago
look forward to more
Julian
688 posts in 419 days
posted 169 days ago
Looking good so far. It sure is fun to work with the old barn wood, isn’t it. I built a harvest table similiar to this one out reclaimed barn floorboards.
-- Julian, Park Forest, IL
wildfire
19 posts in 203 days
posted 169 days ago
Gosh that really stinks..probably the ONLY nail in the lot too wasn’t it? Hope you get to continue with your project soon. Looks great!
-- If you don't try you will never know if you can!
3fingerpat
906 posts in 561 days
posted 169 days ago
Sorry to hear about your setback, looked like you were making good progress.
Is that in 18” Rikon you are using?
Good luck.
Emeralds
155 posts in 456 days
posted 169 days ago
Boy do I own that teeshirt. So often have I worn it that my wife has had my name embroidered on it.
”SlowDownJoe”
-- JMP
CedarFreakCarl
565 posts in 947 days
posted 169 days ago
Thanks for the encouragement. When you get in a rush, you pay for it sometimes. LOL Emeralds…I think I’ve already worn out a few of those t-shirts. Pat: yes that’s an 18” Rikon. Great machine. As soon as I round up some stock I’ll post some more. Thanks again.
stefang
1646 posts in 228 days
posted 168 days ago
Bad luck. It’s is a law of nature that you only hit metal with a brand new blade. We have all been there. My condolences.
-- Mike, American in Norway
