There's A Table in There Somewhere! #2: Milling the Stock for the Legs
Blog entry by CedarFreakCarl posted 238 days ago 256 reads 0 times favorited 9 comments Add to Favorites Watch
« Part 1: The Beginning Part 2 of There's A Table in There Somewhere! series Part 3: Basic Design & Milling the Aprons »
I went down to the my lumber heap down in the barn and retrieved a couple of 4×4’s, a 4×6 and a long (16’) 1” thick board of variable width. My intent was to get enough stock for the table legs and aprons. As you can see, there are plenty of nails to be pulled.
Of course I had my trusty Lumber Wizard to make sure I got them all.
Good news and bad news. First for the good news. I pulled lots of nails.
Now the bad news, a bunch of them broke off due to age and rust.
Normally just a few aren’t much problem depending on what the board is going to be used for. If the legs were just going to be square and straight, I’d just take a nail set and drive them a little deeper so as not to booger up my jointer and planer blades. But in this case, since these are going to be inside tapered legs, I don’t have that option. Sooo, I dropped back and punted. I have some old beams from the same lumber pile.
I thought these next two pics were worth showing just to give you an idea of how old this stuff is. The first picture is a motise in which the tenon has broken off. If you look closely, you can see the tenon pin still intact. The second pic is a tenon on one the the same set of beams. These are about 8”x 8”.
What I ended up doing was dragging out a 4×9 that just happened not to have any nails in it.
It was slightly twisted, so the first thing I did was joint up a flat edge.
There was some termite damage, but not much. I’m not sure, but as hard as this stuff is, they might have dentures now.
Once I jointed both short sides down past the termites, I ripped it down the middle on the bandsaw. I wish you guys could smell this stuff. Smells just like Pine-sol. There’s no wood quite like old heart pine.
Next, I cut them into 32” lengths and squared up an adjacent edge on the jointer. After several trips back and forth between the planer and jointer, I had the base stock for the legs. These are about 3-7/16” square.
Stay tuned…......
-- Carl Rast, Pelion, SC
9 comments so far
View kiwi1969's profile
kiwi1969
601 posts in 342 days
posted 238 days ago
Yeah smell’o’vision sure would be good. I love pine.
View cabinetmaster's profile
cabinetmaster
8749 posts in 458 days
posted 238 days ago
Good looking heart pine. I can’t wait to see the final results.
25871 posts in 1300 days
posted 238 days ago
Nice recovery and some great looking wood.
View oldskoolmodder's profile
oldskoolmodder
707 posts in 580 days
posted 238 days ago
It’s almost hard to believe you can get such beautiful results form what it looked like before hand. Probably what it looked like when it was first used all those years ago.
View griff's profile
griff
942 posts in 662 days
posted 238 days ago
Looking good
-- Mike, Bruce Mississippi = Jack of many trades master of none
View socalwood's profile
socalwood
968 posts in 504 days
posted 238 days ago
Beautiful wood for sure ! I’m looking at the sand in your pics and thinking about knife life ! How dry is the stuff ? Will you relieve them back to show off the pronounced grain ? Rift cut , tasty !!!!
View CedarFreakCarl's profile
CedarFreakCarl
565 posts in 953 days
posted 238 days ago
Thanks Guys!
Socal: you’re right, knives don’t last long when milling sand. I try to at least blow it off with the air hose before planing & jointing. The piece I actually ended up using was pretty pristine and is pretty dang dry. Been sitting in the barn for the last 40 years and then moved to my garage for the last year. I figured on putting the straight/QS grain to the outside and putting the taper to the inside.
View BigBard's profile
BigBard
82 posts in 314 days
posted 238 days ago
Very good post, love the detailed pictures and descriptions. I’m staying tuned!
-- I'm inspired to build a Bombe one day!
View miles125's profile
miles125
1443 posts in 905 days
posted 235 days ago
Beautiful wood! You need a set of slide handle nail pullers. They’re great for broke off rusty nails with minimal gouging of the wood. Do a search on ebay, which is where i got mine. Well woth the cost.
