I have a little vise #1: Intro
Blog entry by BritBoxmaker posted 06-28-2015 11:56 AM 1910 reads 0 times favorited 12 comments Add to Favorites Watch
no previous part Part 1 of I have a little vise series Part 2: Strip down »
Recently I helped my friend, Laurie, set up a lathe and workbench in her shed/ workshop.
For my pains (which weren’t that great, I thoroughly enjoyed it) she gave me this bench vise
It’s going to need some restoring. Rest assured though I won’t just be admiring it when it’s restored. This vise will get some use. Although it’s a metalwork vise I do use metals in my projects. Such as the hinge pins for Snakes and Ladders.
The jaws need some serious attention. One came off in my hand
and the other needs a clean up but looks to be properly secured
The vise seems to be on a rotating base
again possible freeing up to be done.
The main threaded rod seems to be free enough
I was intrigued to find out the maker/model. The only thing I could find on the whole of the body was this
That had to be a name plate. Some light oil and a quick wipe over later
So I tried to find it on google and came up with these images
and
Well thats something to be aiming for.
Be seeing you.
12 comments so far
View grizzman's profile
grizzman
7836 posts in 3267 days
#1 posted 06-28-2015 12:32 PM
well if your restoration work is anything like your woodwork, then i expect this vice to look brand new when your done with it….really nice of her to give you this gift…she will like seeing it after your done with it..have fun…
-- GRIZZMAN ...[''''']
View Sheila Landry (scrollgirl)'s profile
9222 posts in 2884 days
#2 posted 06-28-2015 12:46 PM
My grandfather had a similar vice. I remember trying it out on my finger (Yes – I was THAT stupid!) I did just gently tighten it though, so no harm was done. I was only about 7 or 8 at the time and I definitely learned the purpose of having ‘vices’.
I look forward to seeing how you do in your restoration. :)
Sheila.
-- Designer/Artist/Teacher. Owner of Sheila Landry Designs (http://www.sheilalandrydesigns.com) Scroll saw, wood working and painting patterns and surfaces. "Knowledge is Power"
View parsonpaul's profile
parsonpaul
30 posts in 1207 days
#3 posted 06-28-2015 01:05 PM
Helping others always has its benefit but they aren’t always so … Iron. You can make a set of wooden jaw covers to protect you materials and have a good dual purpose vice.
I’m jealous.
View CharlieK's profile
CharlieK
552 posts in 3757 days
#4 posted 06-28-2015 02:32 PM
You certainly have your work cut out for you but I am sure it will look great when you are done.
-- Adjustable Height Workbench Plans http://www.Jack-Bench.com
View stefang's profile
stefang
15881 posts in 3298 days
#5 posted 06-28-2015 03:18 PM
With a bit of work I’m sure it will look and perform like new. A good metal working vice is a great asset in a woodworkers shop.
View RogerBean's profile
RogerBean
1605 posts in 2917 days
#6 posted 06-28-2015 04:07 PM
I have one just like it, and it works great.
A little soaking in some cheap white vinegar for a few hours or so, and a bit of wire brushing will rid it of the rust and will work like new. The vinegar works surprisingly well. Easier than setting up an electrolysis unit or grinding it off. But then, you probably already knew all that.
Roger
-- "Everybody makes mistakes. A craftsman always fixes them." (Monty Kennedy, "The Checkering and Carving of Gunstocks", 1952)
View Ken90712's profile
Ken90712
17553 posts in 3152 days
#7 posted 06-28-2015 04:27 PM
Thats awesome looks great, Nice save!
View Druid's profile
Druid
1749 posts in 2759 days
#8 posted 06-28-2015 05:31 PM
Well, you always seem to come out on top when you take on a challenge, so this should come out looking and working great. Interesting project.
-- John, British Columbia, Canada
View Philzoel's profile
Philzoel
302 posts in 2307 days
#9 posted 06-28-2015 06:49 PM
I’ve used while maple jaws in my 4” craftsman vice for years. Works great. On my third set.
-- Phil Zoeller louisville, KY
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 3000 days
#10 posted 06-28-2015 08:11 PM
Yes, Phil, whilst I will use the metal jaws (with a pair of aluminium jaw covers) for metalwork I am considering making additional wooden ones. Some flat Maple and some with 45 degree ‘V’ grooves (vertical and/or horizontal) for holding round objects.
Roger, no I didn’t know that. I’ll try it.
View redryder's profile
redryder
2393 posts in 3065 days
#11 posted 06-28-2015 09:14 PM
Here's one I made for my vise (very similar to yours).
Ideas, ideas, ideas.
Good luck on your fix-r-up-r…...........................
-- mike...............
View NormG's profile
NormG
5931 posts in 2968 days
#12 posted 06-29-2015 04:03 AM
It will serve you well
-- Norman - I never never make a mistake, I just change the design.
