Working title - LLB
21K views 54 replies 17 participants last post by  BritBoxmaker
#1 ·
Well lookie here
I'm starting another box. Possible the most complex construction I've attempted to date. It may work, it may not. You never get anywhere new without risk. Well heres the wood for it, most if not all. The dark stuff was labelled 'Mondo'. I don't know what that is but it looks like a rosewood. The red is Padauk.
Rectangle Wood Flooring Floor Wood stain
As for a plan the initial concept is this
Table Furniture Chair Wheel Wood
It may change, to a lesser or greater extent, dependant on limitations of materials, skill and whether or not it stands up for itself. I think it should, tripods are fairly stable.
Suffice it to say this is a real time blog so if any of you out there are keen to make this sort of thing please wait until I have had my chance to suceed (and post it as a project) or fail
#2 ·
Well lookie here
If this is a preview of what is to come, can't wait for the first showing!
Good luck!
Roman
#3 ·
Well lookie here
Looks to be an interesting project. Looking forward to the progress.
#4 ·
Well lookie here
Good wood choice (I am a sucker for padauk). I used a similar color combo for this project (http://lumberjocks.com/projects/65688) albeit not the challenge you're undertaking.
C
#5 ·
Well lookie here
i have full faith in you martyn, im along for the project,
#6 ·
Well lookie here
Very creative plan, I bet it will come out just fine
#7 ·
Well lookie here
Martyn,
You're over my head on the math so far. I'll come back and see if I can even begin to decipher it. As far as skill goes, "Over my head" is a huge under statement.
The book end sides you selected are incredible. Fantastic matching job sir.
I've got to follow this blog to see the magic happen.
#8 ·
Well lookie here
Good luck….can't wait to see this as it evolves.
#9 ·
Well lookie here
Lunar Lander Box?
I have no doubt you can do it Martyn, but where the "Break" is going to be (lid from box) and how you're going to do that has got me confounded… Have Fun!!
#10 ·
So the story begins
The box walls and lid are going to have two layers
Table Chair Art Creative arts Wood
The outside, Mondo (I still don't know if thats a proper name) and the inside, Padauk. The layers are 3 mm thick. The legs and lid decoration will pass through the outer layer and only partially through the inner (in the case of the legs only).
First thing to do is sand down the outside of the outer layer and inside of the inner layer to 400 grit and give them a coat of acrylic varnish.
Brown Rectangle Wood Orange Flooring
Whilst I don't expect this finish to remain totally intact during work on the box it does help cut down on finish sanding on a complex object, when the box is finished.
Before sanding I coded one edge of all pieces so
Wood Brick Brickwork Gas Tints and shades
This, for instance is side (one slash) three. Top pieces have two slashes followed by their number. I also marked the part numbers on the inside faces of each piece.
I routed the 45 degree top and 60 degree sides of each side piece and taped them together.
Wood Rectangle Flooring Floor Road surface
Rectangle Wood Triangle Font Art
On each of the sides to have legs I've drawn a slash on the tape to represent this. They are sides 1, 3 and 5.
Flowerpot Wood Rectangle Flooring Wood stain
The outside only is taped together. I need to make a top and tape that on. Then test the balance of the box by trialing legs taped to the side. That's for the next instalment.
Be seeing you.
#11 ·
So the story begins
Be seeing you.
Thanks for the update Martyn. I never considered beveling the lid so It would automatically seat itself when you place it on top. I really like that idea.
#16 ·
She's got legs.....
....and she knows how to use them.
But first to make up the top.
Those three pieces at the top of the pic will be used to make it. First I printed out a full sized plan from my CAD drawing.
Triangle Rectangle Font Parallel Pattern
and cut out 1/3rd to make a template for two of the pieces.
Rectangle Creative arts Pattern Font Electric blue
Drew out the pieces on the wood using the template
Cutting mat Rectangle Textile Wood Pattern
cut out the middle triangle and marked up the third
Creative arts Pattern Electric blue Circle Paper
Cutting mat Rectangle Sleeve Textile Wood
Cut all three out on the band saw and placed them together
Triangle Wood Creative arts Tints and shades Art
Did a bit of trimming up and glued these together with viscous CA. Cut the remaining 2/3rd out of the template drawing and used it to check the top. The pattern gaps don't matter as a 3 mm angled slot will be cut through the joins. Won't it fall apart you ask? Wait and see.
Green Azure Rectangle Creative arts Aqua
Brown Sleeve Wood Rectangle Tints and shades
before cutting off the remaining waste. Here's the top perched on the sides.
Cutting mat Green Rectangle Wood Composite material
Sanded the mitre edge for the top
Wood Tool Pneumatic tool Gas Saw
Table tilted to 45 degrees, mitre fence at 30 degrees. Here's the result
Wood Rectangle Grass Electric blue Pattern
Which perches neatly on the sides
Wood Rectangle Hardwood Gas Wood stain
In order to keep the sides and top fairly rigidly together I made a liner out of 6 mm MDF, piston fit to the sides/top.
Wood Rectangle Table Gas Flooring
Wood Rectangle Art Flooring Gas
Next the legs. They slant at 13 degrees from vertical and are on three sides only. To test the stability of the design I cut three pieces of scrap sycamore to the required size and double-sided taped them to sides 1, 3 and 5. First marking out where they should go. These strips represent the rear of each leg only and as far as I can see are all that is required to test stability.
Wood Creative arts Rectangle Triangle Electric blue
Rectangle Material property Creative arts Tints and shades Pattern
and she's got legs
Rectangle Wood Art Chair Table
Table Rectangle Outdoor table Wood Outdoor furniture
I prodded and poked it sideways and it appears to be stable enough.
Next thing to do is cut the outer slots. I taped the top to the sides, inserted the liner. Glued some 3 mm balancing strips to the bottom of the liner on the 'leg' sides and drew the centre lines for the three 13 degree angled cuts.
Rectangle Sanding block Flooring Concrete Pattern
Wood Composite material Office ruler Rectangle Hardwood
First I set the blade height so top dead centre of the blade is at the tip of the central triangle.
Automotive tire Wood Tire Motor vehicle Bumper
I set my mitre fence for 77 degrees (13 degrees off vertical with respect to the box sides). and set the top centre line for the centre of the blade.
Saw Table Wood Office ruler Plank
Water Wood Tints and shades Automotive exterior Shade
Squeeky bum time. Made the first cut through the top and sides.
Rectangle Wood Triangle Art Font
If I just do this again with the next cut it will fall into two pieces. To stop this I prepaired a length of 3 mm square Sycamore.
Wood Floor Door Composite material Wood stain
Which I taped into the gap
Wood Road surface Rectangle Asphalt Composite material
Wood Rectangle Floor Composite material Triangle
I cut the other two sides. On the outside this all looks a right mess of masking tape but on the inside
Gas Composite material Concrete Bumper Metal
You can see the desired result. What was not desired was the chip out of the central triangle. No matter I'll make another. Might even make it Ebony. Anyways if you insert a piece of Padauk into the top you can see the angled slot is good.
Wood Creative arts Art Natural material Triangle
That's it for now. I'm knackered for today. More of this nonsense later.
Be seeing you
#17 ·
She's got legs.....
and she's got legs
Be seeing you
After reading, looking and studying all that, I am knackered too and I don't even know what knackered means. LOL
This is going to be a fabulous box when finished.
#23 ·
Old red eyes is back.
Short blog today. Not much shop time.
Cut the 60 degree angles on the sides of the box inner.
Brown Wood Rectangle Table Flooring
and fitted them into the outer shell.
Wood Rectangle Floor Flooring Hardwood
Still nothing glued at this stage as a lot of work to be done on the inner (Padauk) liner before I can even attempt this.
First I need to mark the inside to register the position on the inner where the legs will pass through the outer
Wood Finger Thumb Electric blue Font
Remove the masking tape from one leg side and remove the Sycamore spacer.
Wood Finger Rectangle Wood stain Paint
Its then a simple matter to score lines guided by each side of the slot. Also scored the length to trim the side to. Replace and re-tape the spacer and do the other two leg sides in turn.
Plant Wood Rectangle Natural material Wood stain
Finally made up some pieces for the top liner (3 mm Padauk) and the box bottom from Yeahwhatever, commonly known as Somethingbrownwood. Acquired from my favourite wood supplier, Scrapsbin.
Rectangle Wood Flooring Floor Grass
Brown Wood Rectangle Floor Road surface
Thats all for today, its cold in here and my fingers have gone numb.
Be seeing you.
#24 ·
Be seeing you.
did you not get a heated shop space when you moved…?...so far so good on the box.
#27 ·
A momentary lapse of reason
Happened during this, more later
First thing to do is make up some legs. Padauk, 9 mm square.
Wood Rectangle Office ruler Wood stain Font
Machined to shape on the router table
Wood Floor Wood stain Flooring Hardwood
Ruler Office ruler Wood Font Tool
The leg proper (part that is visible for its whole length) is 3 mm wide and 7 mm deep. The flange on the back is 9 mm wide x 2 mm deep.
A quick try in the box sides
Wood Rectangle Hardwood Flooring Gas
Wood Stairs Wood stain Floor Flooring
Wood Rectangle Art Triangle Tints and shades
Now the flange only goes about halfway up the box sides, I don't want it appearing at the top and ruining the lines.
This means I need to route slots to take the flange in the red liner which I did with this setup
Wood Tool Gas Hardwood Saw
The mitre guage is set to 13 degrees. The jig attached contains the red side pieces whilst routing. The Clamp at the bottom of the picture is the end stop for routing operations. I'm using a 6 mm bit so I've made the jaws of the jig 3 mm further apart than the side width in order to rout a 9 mm slot
Rectangle Wood Floor Flooring Hardwood
Wood Rectangle Bumper Wood stain Automotive exterior
Wood Rectangle Floor Wood stain Flooring
I route only 2 mm into the side so as not to show the flange on the inside of the box.
Brown Wood Rectangle Flooring Amber
I trimmed off the flange from the top (with respect to the box) end
Brown Amber Wood Rectangle Wood stain
Brown Wood Rectangle Plank Hardwood
and inserted it into the complete side. This is where the momentary lapse of reason happened. Panic! When I started to slide the Padauk liner piece into the box the slots didn't line up. I looked away and looked back at it and realised that they would when the liner was fully in place. Phew! They all did
Wood Window Gas Hardwood Tints and shades
Hand Finger Wood Gesture Thumb
Wood Finger Triangle Wood stain Hardwood
so sliding the leg in and taking some tape off I saw this
Wood Finger Triangle Chemical compound Natural material
and it all seems to line up
Window Wood Triangle Creative arts Art
Wood Wood stain Hardwood Flooring Stairs
OK. Back to the shop for some more fun.
Be seeing you.
#28 ·
Be seeing you.
Your precision is really nice to see. Beautiful so far!
Sheila
#33 ·
Rationalise
This thing is getting covered in more and more layers of masking tape. It won't do.
Wood Creative arts Art Flooring Hardwood
So I've decided to take it apart, gradually in order to glue the inner/outer skins and the legs together.
Wood Art Hardwood Rectangle Plywood
Wood Tints and shades Font Metal Wood stain
Again a gradual process, using viscous Cyanoacrylate.
Brown Wood Road surface Amber Rectangle
Tableware Wood Flooring Wood stain Floor
Until all sides were complete
Wood Flooring Floor Road surface Creative arts
I minimally taped these together and took apart the top, perching the pieces on the whole.
Wood Flooring Gas Creative arts Hardwood
Wood Rectangle Creative arts Wooden block Tableware
Wood Creative arts Triangle Art Tints and shades
and I've decided to try repairing the central piece of the lid by splicing on a new bit
Brown Amber Wood Rectangle Tints and shades
That really is all for today
Be seeing you.
#34 ·
Rationalise
Be seeing you.
You have more patience than I. Nice work. This box is going to be very nice when completed.
#41 ·
So much to do ...
... so little time. Why do weekdays crawl by and weekends go before you know it.
Well Somethingbrownwood is not going to do for the bottom of this box. A phrase I'm sure Shipwright is well aware of I don't want to 'spoil the ship for a ha'peth of tar'. I have a little Mondo left.
Brown Wood Wood stain Rectangle Hardwood
This I re-sawed into four 2 mm slices. On the table saw, you don't want to know.
Brown Outerwear Wood Sleeve Grey
I made veneers of this piece( outside bottom of the box), a filler and some 1.5 mm Padauk (inside bottom of the box) and made a 3 ply piece of plywood from these. Using my hexagonal template to mark out a rough cut size for the bottom
Brown Wood Rectangle Triangle Sleeve
Brown Wood Sleeve Flooring Hardwood
Cut this to size on the band saw and put it to one side for now. I used the template to build the top as well. Gluing it to the 3 mm Padauk I'd previously prepared to line up and glue the first Mondo top piece, again using CA. It was then simple to line up the other two pieces using the Padauk strips I would later glue into the top as spacers.
Brown Wood Triangle Wood stain Hardwood
Trimmed and sanded this down on the belt sander.
Wood Amber Gesture Finger Material property
Brown Wood Rectangle Flooring Wood stain
Brown Wood Triangle Rectangle Flooring
I trimmed the repair of the top piece
Creative arts Finger Thumb Art Triangle
on the disc sander. I usually mark the bit not to be touched (this time with white pencil)
Hand Wood Finger Thumb Tints and shades
to avoid sanding into this.
Located it in the top again using the top Padauk pieces as guides
Wood Gas Composite material Metal Pattern
and glued it into place. I then sanded the compound angle on the inner ends of the padauk details and glued them into place (CA again). Returned to the belt sander and trimmed the outside edges. I got carried away then and finish sanded the mitre on the tops of the sides. No pictures. Then placed the top on the taped together sides
Drinkware Wood Tableware Coffee cup Cup
Gave it a bit of a spray with Acrylic, to show up anything that needs attention and adjusted as necessary. Flattened the top of the Padauk on the disc sander.Trimmed the legs to length and this is what we have so far
Azure Wood Rectangle Cutting mat Triangle
Wood Triangle Art Creative arts Rectangle
That really is enough for me, for one day.
Be seeing you.
#42 ·
So much to do ...
Be seeing you.
I got lost about halfway through but I DID read through the whole process. This is going to be an amazing box when finished.
#47 ·
Closing Time
Just a short blog as there's not much left to do. I need to cut the slots to accept the bottom.
Wood Gas Brick Flooring Brickwork
The end stop is cunningly sized so that the sides with legs don't foul it. Slot 1.6 mm deep.
Wood Rectangle Wood stain Floor Hardwood
Final tape up ready for gluing
Table Cutting mat Green Wood Liquid
Table Cutting mat Rectangle Wood Textile
and glued up (PVA) with the top taped on (but obviously not glued) to maintain the box shape whilst drying.
Wood Creative arts Table Art Rectangle
Next time you see it will be when I've taken the top edges down a bit with 600 grit (they are razor sharp at the moment) and applied the final finish, posted as a project.
Be seeing you.
#48 ·
Closing Time
Be seeing you.
Looks real good. A little reminiscent of the stool stretchers used on the 3 legged stool.
