Working title - LLB #4: Old red eyes is back.
Blog entry by BritBoxmaker posted 12-08-2014 07:43 PM 1620 reads 0 times favorited 3 comments Add to Favorites Watch
« Part 3: She's got legs..... Part 4 of Working title - LLB series Part 5: A momentary lapse of reason »
Short blog today. Not much shop time.
Cut the 60 degree angles on the sides of the box inner.
and fitted them into the outer shell.
Still nothing glued at this stage as a lot of work to be done on the inner (Padauk) liner before I can even attempt this.
First I need to mark the inside to register the position on the inner where the legs will pass through the outer
Remove the masking tape from one leg side and remove the Sycamore spacer.
Its then a simple matter to score lines guided by each side of the slot. Also scored the length to trim the side to. Replace and re-tape the spacer and do the other two leg sides in turn.
Finally made up some pieces for the top liner (3 mm Padauk) and the box bottom from Yeahwhatever, commonly known as Somethingbrownwood. Acquired from my favourite wood supplier, Scrapsbin.
Thats all for today, its cold in here and my fingers have gone numb.
Be seeing you.
3 comments so far
View grizzman's profile
grizzman
7836 posts in 3452 days
#1 posted 12-08-2014 10:00 PM
did you not get a heated shop space when you moved…?...so far so good on the box.
-- GRIZZMAN ...[''''']
View shipwright's profile (online now)
shipwright
8086 posts in 2946 days
#2 posted 12-09-2014 06:02 AM
Interesting …......
Stay warm Martyn. We can wait a little longer …... but not toooooo long. :-)
View Sheila Landry (scrollgirl)'s profile
9237 posts in 3068 days
#3 posted 12-09-2014 11:26 AM
I had a little ceramic heater when my shop was in my garage. It was not too expensive but did wonders to keep my hands warm. I also cut the fingers out of some gloves and I was able to last much warmer that way. It is looking good so far. I look forward to subsequent reports.
Sheila
-- Designer/Artist/Teacher. Owner of Sheila Landry Designs (http://www.sheilalandrydesigns.com) Scroll saw, wood working and painting patterns and surfaces. "Knowledge is Power"
