Applique #1: Testing, testing
Blog entry by BritBoxmaker posted 08-26-2014 07:36 PM 1750 reads 1 time favorited 6 comments Add to Favorites Watch
no previous part Part 1 of Applique series no next part
Not sure if applique is the right term here. I’ve started exploring designs with a basic background with contrasting pieces of wood ( of varying thickness ) glued on. This is the first test piece
It’s a piece of Birch ply, dyed black ( spirit based dye ). I usually use spray Acrylic finish these days. I tried using this as an adhesive. I then made up a pattern of 2 mm strips of Sycamore veneer on some transparent library film ( the sticky sort ) and applied this ( veneer side down ) to the wet finished base board. but with no result.
After allowing a couple of hours to dry (it usually goes off in 10 minutes) the pattern came straight off the base board so the next time I applied a uniform coat of PVA glue to the board instead. As this dries transparent it doesn’t affect the background colour. Positive result this time. Acrylic finish should also take to the whole pattern/ base board as well.
That’s all for now.
Be seeing you.
6 comments so far
View stefang's profile
stefang
15940 posts in 3476 days
#1 posted 08-26-2014 07:39 PM
Applique sounds like a good description of the technique to me.
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 3178 days
#2 posted 08-26-2014 07:57 PM
Thanks, Mike.
View KnotCurser's profile
KnotCurser
2026 posts in 3210 days
#3 posted 08-26-2014 08:13 PM
Good read – I could see a use for this with my CNC Router as well.
Must keep this in mind.
Thanks!
-bob
-- Robert Rhoades WoodWorks / Email: rrww@rhoadesclan.com / www.rhoadesclan.com
View footprints's profile
footprints
45 posts in 3250 days
#4 posted 08-26-2014 08:33 PM
Have you solved your deep dying problem? The spirit based dye should penetrate birch well but may not get too deep on harder woods. As we discussed, I use vacuum impregnation to get all the way through but if you have discovered a low surface tension dye that accomplishes this without the vacuum hassle, please let me know!
I wonder if you will have to counter veneer the bottom surface of thin (<6mm) substrates if you apply less than 100% veneer on the top surface? I have never heard of partially covering a substrate with varying thickness woods and suspect you are heading into uncharted waters once again.
I anxiously await where this new line of exploration leads.
-- Ray, Lakeland, FL
View Sheila Landry (scrollgirl)'s profile
9237 posts in 3061 days
#5 posted 08-27-2014 01:04 PM
I will watch with interest. This will be a good learning experience for us all. :)
Sheila
-- Designer/Artist/Teacher. Owner of Sheila Landry Designs (http://www.sheilalandrydesigns.com) Scroll saw, wood working and painting patterns and surfaces. "Knowledge is Power"
View Dark_Lightning's profile
Dark_Lightning
3254 posts in 3250 days
#6 posted 09-10-2014 02:08 AM
OK, don’t leave us hanging! Where did you go from here?
-- Random Orbital Nailer
