Fibonacci Mosaic box #6: Results of caulk experiment
Blog entry by BritBoxmaker posted 10-05-2013 12:26 PM 2286 reads 1 time favorited 5 comments Add to Favorites Watch
« Part 5: Further grouting experiments Part 6 of Fibonacci Mosaic box series no next part
Firstly it occurred to me that although I needed a pattern to experiment that it didn’t need to be fancy. To this end I took a scrap of MDF and cut 2 mm slots in it using the table saw blade set low.
Applying the caulk using the gun and fine nozzle was like trying to pass an elephant. Slow and painful. So I decided to use a putty knife to apply it.
This stuff cures by losing water so I expected some shrinkage and because of that didn’t level it off completely.
After a day this was the result.
Shrinkage evident. So sanded back level this is what I had.
It is not hard but flexible even when cured. I spray coated some acrylic finish . This appeared to take well.
Left the piece until today (5 days total) with this result
and the end, sanded off flat
Some further shrinkage. Though I don’t think its an unattractive result. The filler is still elastic. May be a better long term bet given wood movement. We shall see. Thats all.
Be seeing you.
5 comments so far
View Roman - THE BOOTMAN's profile
Roman - THE BOOTMAN
916 posts in 2591 days
#1 posted 10-05-2013 01:29 PM
Martyn, thanks for the post. You have given me some ideas for my boot carvings! Thanks!
-- Author of POWER CARVING BOOTS & SHOES - Schiffer Publishing. Available online or your favourite bookstore.
View jap's profile
jap
1251 posts in 1959 days
#2 posted 10-05-2013 01:52 PM
great experiment
-- Joel
View jaykaypur's profile
jaykaypur
4017 posts in 2314 days
#3 posted 10-05-2013 05:22 PM
Good experiments and also, good to know!
-- Use it up, Wear it out --------------- Make it do, Or do without!
View Steven Davis's profile
Steven Davis
118 posts in 2820 days
#4 posted 10-06-2013 04:50 PM
Martyn -
Interesting as always. What about a classic wood filler – sawdust and glue, colored to suit?
-- Steven Davis - see me at http://www.free2secure.com/
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 2942 days
#5 posted 10-06-2013 04:53 PM
Yes, Steven. Another possibility. It might be difficult to get a light colour though, such as white. Darker should be fine though.
