In the light #1: Everybody needs the light
Blog entry by BritBoxmaker posted 07-27-2013 03:55 PM 1866 reads 2 times favorited 13 comments Add to Favorites Watch
no previous part Part 1 of In the light series Part 2: So the story begins »
I’m back in the shop after 44 days absence due to back injury.
Check; clear bench, tea, custard creams, music.
Now lets make boxes!
Well to start some experimentation. The liners for my EZ mitre boxes are Birch ply. The one for the last box, Amazed, was dyed black (spirit based wood dye used in Dance on a Volcano II and Any Colour You Like) and sprayed with satin acrylic spray. I’ve found that the same company that make the clear acrylic spray make this
An ebony finish. I wonder if this would be a better first coat for the liner on my new box? Also will cyanoacrylate (super glue) stick to it better or worse than to straight dyed Birch? Could it be less messy?
After putting a 3mm sheet of Birch ply through the drum sander, to clean it up, I spayed a coat of the Ebonising lacquer on it.
When this was dry I nibbed (removed the dust particles trapped under the lacquer) the board with 400 grit.
This made it somewhat matt. This should improve the glue adhesion. Plus any lightening should be corrected with the final coat of clear lacquer. You’ll get the pattern idea for the new box from the next shot. This is after the Sycamore pieces have been glued to the liner and after clear lacquer is applied over the top of the construction.
The joints of the inner two right angles are straight from the table saw (80 TPI crosscut blade) the outer’s joint is after cleaning up on the belt sander. The mess on the upper edge of the bottom strip is due to my laziness with the CA glue.
So experiment successful. This method works at least as well as the previous one. It may have advantages (like better glue adhesion) but its more expensive. The box better be worth it, I’ve already sprayed the liner.
And, of course the light of which I speak is that of knowledge born out of experimentation and experience, not belief.
Be seeing you
13 comments so far
View Sheila Landry (scrollgirl)'s profile
9221 posts in 2850 days
#1 posted 07-27-2013 04:13 PM
Looking forward to seeing the finished box. From the photographs, the color looks nice and deep. It is smart to see you testing this method before jumping in with both feet. So many people do that and then ruin what should have been nice pieces.
Good start . . .
-- Designer/Artist/Teacher. Owner of Sheila Landry Designs ( Scroll saw, wood working and painting patterns and surfaces. "Knowledge is Power"
View grace123's profile
233 posts in 2693 days
#2 posted 07-27-2013 04:32 PM
I hope your back is totally better. Your tutorials and excellent. You are the standard by which I measure my own efforts. I have a very LONG way to go to meet your virtuosity.
View BritBoxmaker's profile
4611 posts in 2967 days
#3 posted 07-27-2013 04:40 PM
Thank you, Sheila. It also helps me pace myself for getting back (pun unintentional) to my work.
Thanks also, Grace. We ALL started somewhere. That we did and that we want to improve are the important things. I still have things I want to achieve that I am nowhere near yet. The road may seem long but its full of interesting turns we aren’t aware of. Have fun.
View Bearpie's profile
2601 posts in 2948 days
#4 posted 07-27-2013 05:23 PM
I do know what back problems can be like, I suffered greatly a few years ago but since I had a total knee replacement, I have not had an attack! For me at least, the problem was my knee and possibly me favoring it caused back problems? Aside from that, I’m glad you are feeling better and back in the shop creating. It looks like your next project is going to be awesome.
-- Erwin, Jacksonville, FL
View SPalm's profile
5316 posts in 3812 days
#5 posted 07-27-2013 07:57 PM
Welcome back Martyn.
The testing looks great. My that is really black.
-- -- I'm no rocket surgeon
View Doe's profile
1402 posts in 2760 days
#6 posted 07-27-2013 08:03 PM
Welcome back! I’m glad you’re feeling better.
-- Mother Nature talks, I try to listen
View kenn's profile
810 posts in 3650 days
#7 posted 07-27-2013 10:03 PM
I am so glad you are back in the shop! Glad you’ve recuperated well enough to get back at what you enjoy. Remember to start back slow, be careful. Looks like you are off to a great start on this project.
-- Every cloud has a silver lining
View Roger's profile
20916 posts in 2734 days
#8 posted 07-27-2013 11:49 PM
Glad your feelin better and “back” in the shop also. Work/Play safe. Back injuries suck.
-- Roger from KY. Work/Play/Travel Safe. Keep your dust collector fed.
View longgone's profile
5688 posts in 3239 days
#9 posted 07-28-2013 12:49 AM
been there…done that with the back injuries…Make you appreciate feeling normal.
View Dark_Lightning's profile
3114 posts in 3039 days
#10 posted 07-28-2013 02:31 AM
I wondered where you had gone! My back has given me trouble about this time of year for the last two years. I think I’ve got it figured out. We’ll see. Welcome back. Interesting treatment of the wood, I like ebony. It’s kind of expensive, though.
-- Random Orbital Nailer
View steliart's profile
2596 posts in 2618 days
#11 posted 07-28-2013 11:02 AM
good to see you back, wishing you all the best health
-- Stelios L.A. Stavrinides: - I am not so rich to buy cheap tools, but... necessity is the mother of inventions
View littlecope's profile
3071 posts in 3432 days
#12 posted 07-28-2013 11:56 AM
Nice to see you return Martyn and looking forward to seeing your latest Work too!!
I hope you notice that I did not use the B-word… :)
View Druid's profile
1735 posts in 2726 days
#13 posted 08-17-2013 01:45 AM
Great to hear that you have returned, and I too am looking forward to the unveiling of your next creation.
Glad to hear that you are feeling better . . . must be the custard creams.
-- John, British Columbia, Canada
