A busy day and that’s just making the hinge. First thing to do is cut up the material into four pieces.
then mark up the pieces, including where the slot is to be routed.
The next thing to do is route the pin slot. The pin is to be enclosed (not visible at the ends of the hinge). The hinge is 125 mm long, allowing 6 mm of un-routed material at each end, leaves a 113 mm long slot. To set the router table up for this I installed a 45 degree router bit, marked up one piece of the hinge for two points separated by 113 mm and aligned the tip of the bit on one mark and placed a block of scrap on the fence (attached by double sided tape), so
Repeating this for the other side. Then routed
Doing all four pieces. This shows one half of the hinge open and the other closed
In order to mark up and cut the hinge fingers the pieces were double sided taped together
and the slot routed edges masking taped together (masking tape underneath in this shot).
The fingers were marked up and the waste areas (cross hatched) removed on a scroll saw. Next to round off the outer piece edges. The inners don’t need to be rounded as the box lid cannot rotate inwards ( try looking at a solid metal butt hinge, you’ll see what I mean). These pieces only have one or two contact points so I double sided taped them to a longer, continuous, piece of MDF as a guide for routing.
Here’s the bit used, a 4.5 mm rounding bit.
The pieces together, complete with pin
and all together
Next I routed a 6 mm slot ( on the outside of the hinge) to take the piece thickness either side of the barrel of the hinge down to 6 mm ( the box wall thickness).
Then another 6 mm slot, 1mm further from the barrel, down to the spline width (you’ll see)
and routed the same slot on the inside, down to the spline width
Now the eagled eyed amongst you will probably be thinking ‘those barrel sides are only rounded on one side’. Correct. I don’t have a rounding bit that would do the other sides of the barrel so I routed a 45 degree slope along both sides (just shy of the existing round edges) and rounded these off with a file and sand paper to give this
Then I trimmed off the excess on the bandsaw giving
That’s the hinge made. Enough for me, today. Next time I fit the hinge in the box.
Be seeing you.
-- Martyn -- Boxologist, Pattern Juggler and Candyman of the visually challenging. http://www.theartofboxes.com
14 comments so far
michelletwo
home | projects | blog
1767 posts in 1185 days
#1 posted 122 days ago
I rarely read blogs here on LJ’s. Don’t want to put radical ideas into my head!! :-) But I have been aware of your blog , and I have marveled at your willingness to break your train of thought & work to take pictures and then the time to do the blog. You are a woodworking/sharing gentleman of the first order. I hope folks take the time to thank you and tell you how much they appreciate your efforts.
-- We call the destruction of replaceable human made items vandalism, while the destruction of irreplaceable natural resources is called development.
nomercadies
395 posts in 508 days
#2 posted 122 days ago
This is like watching “The Brain Operation Channel” then thinking I can do an operation after watching one of the shows. I will continue watching and being mesmerized by the skills, but … I’m not thinking I will ever do an operation of this delicate nature. Thank you doctor.
-- Chance Four "Not Just a Second Chance"
bigike
4023 posts in 1458 days
#3 posted 122 days ago
Nice
jaykaypur
2500 posts in 577 days
#4 posted 122 days ago
Good job and look forward to the next step.
-- Use it up, Wear it out --------------- Make it do, Or do without!
amagineer
1021 posts in 766 days
#5 posted 122 days ago
You have conquered the hinge problem with flair.
-don
-- Flaws are only in the eye of the artisan!
stefang
9472 posts in 1504 days
#6 posted 122 days ago
This looks like excellent work Martyn and with some very precise routing work too. More importantly the hinges look understated and unobtrusive, which in most cases I prefer , although some decorative wooden hinges can be very nice too if they are not too bulky looking. Your blog is very clear and informative as well.
-- Mike, American in Norway
grizzman
5386 posts in 1473 days
#7 posted 122 days ago
very interesting, and i agree with mike, i am a fan of wooden hinges and of ways to use them and of different ways to incorporate them, im looking forward as to what will they be attached to…grizz
-- GRIZZMAN ...[''''']
Sodabowski
1811 posts in 1002 days
#8 posted 122 days ago
Yet another great idea put to practice and shared with the mere mortals. Thanks Martyn :)
-- Thomas - There is no such thing as a problem, there only are solutions.
littlecope
2329 posts in 1671 days
#9 posted 121 days ago
Nice Work Martyn!
Looking forward to the attachment…
Kate
390 posts in 2044 days
#10 posted 121 days ago
amazing
nicely done
-- Kate, http://www.wooden-box-maker.com
gfadvm
6635 posts in 859 days
#11 posted 121 days ago
I can’t keep up with the process but you have given me some ideas for a new style wooden hinge. I love the whole clamshell design but got lost at the shaping/routing of the hinge ‘bases’. Not to worry though: it will undoubtedly make more sense to me when I see them mounted. Keep on keepin on!
lanwater
2420 posts in 1103 days
#12 posted 121 days ago
All I can say is you are really resourcefull and overflow with ideas.
Thanks for sharing.
Roger
9191 posts in 973 days
#13 posted 121 days ago
Coming along nicely. The only thing I see that makes my hair stand up is that little piece and your fingers so close to that cutting bit. Please be careful.
jap
1031 posts in 223 days
#14 posted 121 days ago
cool
-- Joel -- http://diversitywoodworks.wordpress.com
