We all make mistakes. Yes even me. I’ve been working on the design and build of a box for the best part of a month and a half now. You know I don’t like chunky boxes, the sort with way too thick walls. This box is about 125 mm square x 75 mm high. So I’ve made the wall thickness 6 mm, slightly on the thin side but not a problem for a shell or drop on lid box. Except this one has a wooden clam shell hinge (see first part of blog). This was a mistake
as the consternated look on the back of this box shows.
I tried to CA glue the broken pieces back in, to try and fix it, to no avail.
The weight of the box lid is too great for the size of hinge. The grain direction was also wrong.
Now its an anamorphic patterned, EZ Mitre box. A lot of design and build time went into it. I could have cried. I swore a lot, in several languages.
So I had a long think. One of my 3:00 am in the morning, long thinks. I came up with a new angle on what is basically an engineering approach (thank you MOD (DOD) training), retrofit hinges. This is the basic design
The top and bottom are 6 mm long, 2 mm hidden splines which will be buried in the box back (with 2 mm of back material on each side). Here the hinge is at various degrees of ‘opening’ seen from outside
and inside
The ‘meat’ of the hinge is 9 mm across and so much more substantial. The extra 3 mm of hinge will protrude from the back of the box. As its curved this should not look too inelegant. I’ll rescue the original 2 mm brass pin from the box as I will be cutting out material to give room for fitting the hinge as well as routing out slots for the splines to fit into. I’ll detail the make on the hinge as well. This is the type used for Pac Man, an earlier box.
To start I’ve cut and thickness sanded a piece of 4.5 mm Ebony
Cut into pieces 60 mm long
Re- arranged for correct grain direction for a wooden hinge
and glued up and drying, as I blog.
Are you sure Hank done it this way?
Thats all for now.
Be seeing you.
-- Martyn -- Boxologist, Pattern Juggler and Candyman of the visually challenging. http://www.theartofboxes.com
15 comments so far
stefang
home | projects | blog
9448 posts in 1501 days
#1 posted 121 days ago
These hinges look very good to me Martyn. It is worth all the time and trouble to come up with something so attractive and useful at the same time. I’m looking forward to seeing them fully constructed and then in action.
-- Mike, American in Norway
shipwright
3377 posts in 965 days
#2 posted 121 days ago
Very good solution Martyn.
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/
Roger Clark aka Rex
6241 posts in 1602 days
#3 posted 121 days ago
Martyn, that was no mistake, you just became un-hinged. lol
Good post, waiting to see the finished article.
-- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time.
Jamie Speirs
3671 posts in 1024 days
#4 posted 121 days ago
Martyn Shirley says that I only make two mistakes
All I say and all I do.
I think those hinges will be a lot better and it is the
delicate detail that you enjoy.
I wait for the next part.
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
BritBoxmaker
4006 posts in 1203 days
#5 posted 121 days ago
Yes Jamie. Reminds me of the old joke.
If a man says something in the middle of a forest and there is no woman to hear him, is he still wrong?
Kate
389 posts in 2042 days
#6 posted 121 days ago
I love it when the 3am flashes of brilliance turn out to be actually brilliant.
Looking forward to seeing the final product.
-- Kate, http://www.wooden-box-maker.com
Sodabowski
1805 posts in 1000 days
#7 posted 121 days ago
Aw. Looking forward to the end result.
-- Thomas - There is no such thing as a problem, there only are solutions.
Sheila Landry (scrollgirl)
5926 posts in 1087 days
#8 posted 120 days ago
I am also looking forward to seeing how it works out. Keep at it Martyn. :)
Sheila
-- Contributing Editor, Creative Woodworks and Crafts, Sheila Landry Designs http://www.sheilalandrydesigns.com "Knowledge is Power"
SPalm
4108 posts in 2049 days
#9 posted 120 days ago
I just love those middle of the night thought patterns. Nice to know you get them too.
Looking great Martyn. It’ll be great to see the end result.
Steve
-- -- I'm no rocket surgeon
jaykaypur
2495 posts in 575 days
#10 posted 120 days ago
I think Hank did do it that way ! LOL
Good job.
-- Use it up, Wear it out --------------- Make it do, Or do without!
amagineer
1016 posts in 764 days
#11 posted 120 days ago
Early morning is the best time for coming up with solutions ( less distraction when it is quiet). looking forward to the finished box.
-don
-- Flaws are only in the eye of the artisan!
gfadvm
6623 posts in 857 days
#12 posted 120 days ago
It’s good to know that you are human after all! I thought you were a box making machine. Your ‘fix’ looks like another brainstorm to me. Is Hank popular in the UK? He’s one of my favorites.
BritBoxmaker
#13 posted 120 days ago
Country is not very popular here but I liked the Waylon Jennings song about Hank Williams. I find it doesn’t really matter what sort of music you prefer, there are always one or two good songs in other genre out there. Mostly like Rock myself but am also partial to the odd classical, Glenn Miller, Folk song etc.
gfadvm
#14 posted 119 days ago
Waylon is way up toward the top of my list (but you were pretty certain I was a country fan!). I admire your perseverence in fixing your current project. Best luck and keep us posted.
mafe
8055 posts in 1256 days
#15 posted 119 days ago
Auuch.
But I am sure the result will be even better.
Best thoughts,
Mads
-- Mad F, the fanatical rhykenologist and vintage architect. Democraticwoodworking.
