Any Colour You Like #4: Brain Damage
Blog entry by BritBoxmaker posted 10-28-2012 08:03 PM 2050 reads 0 times favorited 15 comments Add to Favorites Watch
« Part 3: Us and Them Part 4 of Any Colour You Like series no next part
The board from yesterday’s glue up was a success
To trim this to size I cut the inner hexagon out of the paper plan.
I cut through the alignment marks at the edge, flipped it and lined it up over the pattern.
Using the same scalpel blade marking trick to define the outline. I then joined up the marks with scalpel and ruler.
Finally cutting all the way through ( its only two layers of veneer and a core of MDF, after all). This sat nicely on the top of the sides.
I set up the belt sander, 45° for the table, 60° for the fence, to mitre the top
and glued it in
Next I made up the six diamond patterns for the pillar tops mitring in a similar way
and laid one, in place, on the top
It sat a bit high.
After scratching my head for a few minutes I realised that it was the thickness of the veneer on the top too high. I’d forgot to allow for that. No matter. I just needed to sand off the bottom 0.5mm of each. I made a quick holder for these
from a sheet of 1.5mm ply and passed them all through the drum sander. I then blacked one up
and tried it in place
That looked alright so I did the other five
Next I needed to take out the tips to accommodate the central ‘moon’. I made up a jig so
Boring out the centre with a 32 mm Forstner bit. The diamond fitted in thus
and I just sent the bit down again to cut out the correct radius curve from the tip. All six placed on the top
I made up a circle from 6 mm Sycamore, rounding the top on the router and laid it in
Thats all I’m showing for now. Its a shell box so not top cut and I still need to make a base for it.
Be seeing you
-- Martyn -- Boxologist, Pattern Juggler and Candyman of the visually challenging. http://www.theartofboxes.com
15 comments so far
View Roger's profile
Roger
20898 posts in 2679 days
#1 posted 10-28-2012 08:32 PM
“I’ll see you, on the Dark Side o the Moon”
View BertFlores58's profile
BertFlores58
1685 posts in 2798 days
#2 posted 10-28-2012 10:08 PM
Well done! I can see how precise you do the impossible. Cheers
-- Bert
13594 posts in 3217 days
#3 posted 10-28-2012 10:10 PM
he do’od it
and he dude it good
View Roger Gaborski's profile
Roger Gaborski
244 posts in 3624 days
#4 posted 10-28-2012 10:23 PM
This is an amazing box! You definitely have special gifts -patience and attention to detail.
Roger
-- Roger Gaborski, http://www.rogergaborski.com
View Sodabowski's profile
Sodabowski
2370 posts in 2708 days
#5 posted 10-28-2012 11:04 PM
May I complain about something I see as a flaw here? The pilar top diamonds, I would have cut them with the grain along their longest diagonal, you made them with the grain along one edge, and you didn’t put them with that same long-grain edge on the same side. Yes, I know I’m picky… Otherwise I keep loving that project!
-- Thomas - Pondering the inclusion of woodworking into physics and chemistry classes...
View BritBoxmaker's profile
BritBoxmaker
4610 posts in 2912 days
#6 posted 10-28-2012 11:10 PM
Yes you are picky, Thomas.
I am happy with what I have done but then I don’t claim to be perfect. No one is.
BertFlores58
#7 posted 10-28-2012 11:11 PM
Wow! Small means less materials but work has highest difficulty.
Have fun in doing it.
-- Bert
View CalgaryGeoff's profile
CalgaryGeoff
937 posts in 2357 days
#8 posted 10-29-2012 12:27 AM
Fantastic! Your work is very unique and with intricate design features.
-- If you believe you can or can not do a thing, you are correct.
View gfadvm's profile
gfadvm
14940 posts in 2566 days
#9 posted 10-29-2012 01:53 AM
Your solutions continue to fascinate me: miters on the belt sander, cutting the ends of those wedges with the drillpress; you are one of those guys that can always come up with a plan (and then have it work!). I remain in awe. To my eye, this appears your most difficult build to date.
View sras's profile (online now)
sras
4701 posts in 3005 days
#10 posted 10-29-2012 02:47 AM
Looking awesome! This has been a fun one to follow.
View Druid's profile
Druid
1706 posts in 2671 days
#11 posted 10-29-2012 03:23 AM
Interesting methods are always great to learn, and you’ve just shown us a couple more. Looks good.
Thanks again for sharing.
-- John, British Columbia, Canada
View oldnovice's profile
oldnovice
6479 posts in 3243 days
#12 posted 10-29-2012 03:36 AM
If I was 20 years younger and had a head start of 10 years or so I still could not master all of the techniques you demonstrate but t is still fun to watch and learn from a box master!
Do I need to say I like this?
BritBoxmaker
#13 posted 10-29-2012 01:20 PM
The finished project is posted here
View Sheila Landry (scrollgirl)'s profile
9220 posts in 2795 days
#14 posted 10-30-2012 01:44 PM
This came out wonderfully! Just a beautiful job! :)
Sheila
-- Designer/Artist/Teacher. Owner of Sheila Landry Designs (http://www.sheilalandrydesigns.com) Scroll saw, wood working and painting patterns and surfaces. "Knowledge is Power"
View NormG's profile
NormG
5889 posts in 2879 days
#15 posted 10-30-2012 06:44 PM
Wonderful box any way you cut it. Great colors also
-- Norman - I never never make a mistake, I just change the design.
