How to make and fit the top. Initial thoughts were to go back to the CAD model and produce a template that way.
This is fine in that it is roughly the right size and shows all the pieces in their places. Slight problem though. This is an ideal picture. If I were making the top and sides and putting them together in one go it would be perfect to use. However I have already made and glued up the sides. With the best will in the world the resulting hexagon of sides is not going to precisely match to this diagram. So back to the real world. A plain piece of A4 paper and the sides placed on it top end down.
I used a scalpel to prick holes in the paper along the outside of the pillars. Join these dots up using pencil and ruler. Whilst your at it find the centre from the corners of this drawing, so
Found the centres of each of the rainbow patterns (join between yellow and green) again using a scalpel dot, join the point to the centre and extended outwards, so
Did the same with the double line representing the white line on adjacent sides.
Draw in the lines to give this (the black corner is a registry device, one of the black pillars on the base has the mitred side blacked to correspond)
The sharp eyed amongst you will notice there is also an extra, internal, hexagon. This is the actual size of the top and is derived by going around the existing hexagon with a piece of spare pillar material, marking dots to join up to create this, so
Black and white pieces were cut to size
and laid out on the plan to check
Next to cut the triangles for the colours. Only orange, yellow, green and blue need be trimmed to triangles, red and purple can stay pretty much as they are. I made a simple jig from a piece of veneer
with a 52mm x 6mm cutout at the corner and a piece of plastic double sided taped to it.
The veneer to be cut fits in it thus
and is cut with a scalpel to produce this
I tried these wedges out on the CAD diagram with a piece of pillar material to cover
I taped a piece of clear library film, sticky side up, to the real world diagram and laid the pieces on it
Filling in the gaps with spare veneer (Birch, white). This was glued to the MDF top material, with a black veneer (inside of box) on the other face and is drying in my veneer clamp as I write.
All for now
Be seeing you
-- Martyn -- Boxologist, Pattern Juggler and Candyman of the visually challenging. http://www.theartofboxes.com
15 comments so far
Sheila Landry (scrollgirl)
home | projects | blog
5924 posts in 1086 days
#1 posted 203 days ago
How many ways can I say “Wow!” You are really an amazing designer, Martyn. Incredible.
Sheila
-- Contributing Editor, Creative Woodworks and Crafts, Sheila Landry Designs http://www.sheilalandrydesigns.com "Knowledge is Power"
12048 posts in 1507 days
#2 posted 203 days ago
great build sequence martyn
you da man
86945 posts in 1743 days
#3 posted 203 days ago
A great blog Martyn thanks for sharing your amazing know how.
Sodabowski
1800 posts in 999 days
#4 posted 203 days ago
What Sheila said.
-- Thomas - There is no such thing as a problem, there only are solutions.
SPalm
4099 posts in 2048 days
#5 posted 203 days ago
What Thomas said.
Steve
-- -- I'm no rocket surgeon
Druid
425 posts in 961 days
#6 posted 203 days ago
I’m glad that your “cold” didn’t get the better of you during that sequence. Imagine what one energetic sneeze would have done . . . ? If I had to show someone a clear example of patience, I would point them to this project. Looks great Martyn.
-- John, British Columbia, Canada
jap
1029 posts in 220 days
#7 posted 203 days ago
love your work
-- Joel -- http://diversitywoodworks.wordpress.com
JL7
3594 posts in 1131 days
#8 posted 203 days ago
What Steve said!
-- Jeff - I have not failed. I've just found 10,000 ways that won't work.
BritBoxmaker
4003 posts in 1202 days
#9 posted 203 days ago
Hmmm, shame there’s no ‘Like’ button. Thanks everyone.
This is going better than I had expected.
More tomorrow.
#10 posted 203 days ago
what martyn said lol
BritBoxmaker
#11 posted 203 days ago
Like !
NedB
610 posts in 1731 days
#12 posted 203 days ago
thud
that was my jaw dropping on the desk.
-- Ned - 2B1ASK1 http://nedswoodshop.blogspot.com
BertFlores58
1527 posts in 1088 days
#13 posted 203 days ago
You make the rainbow shine!
-- Bert
gfadvm
6611 posts in 856 days
#14 posted 203 days ago
Thanks for the insight into how you approach/solve these “insurmountable” design problems. I learn something new every time I click on one of your posts.
TopamaxSurvivor
13192 posts in 1842 days
#15 posted 203 days ago
Makes my head spin ;-)
