Any Colour You Like #2: Breathe
Blog entry by BritBoxmaker posted 10-21-2012 05:34 PM 2152 reads 0 times favorited 20 comments Add to Favorites Watch
« Part 1: Design and experimentation Part 2 of Any Colour You Like series Part 3: Us and Them »
The board came out of glue-up OK.
First thing to do, trim the excess off the bottom edge.
Now the vertical rounded pillars. They were going to be Ebony but such was the dye success with the black that I decided to opt for dyed Sycamore. This is English Sycamore, which is a creamy white, not it’s American cousin.
I cut the above wide enough to do both sides of a box corner and rounded both edges. Then dyed them up.
The sun came out. For a moment I thought I wasn’t in England any more. When dry these two pillar strips were cut into approx’ 100mm lengths, 7 required. The placing of these on the pattern is a precise thing. I made a simple plastic jig, 36mm wide with a line 6mm in from each edge.
This is placed over the rainbow section of the pattern.
I had cut the red and purple strips 8mm wide to allow an overlap, covered by the pillar. The pillar piece is then placed up against the jig and glued to the pattern.
This is done on both the red and purple sides and the jig removed.
seven pillars were glued on in this way, giving.
Next thing to do is rout a 60 degree groove, from the rear, up the centre of each pillar piece. I used my long jig, Wide Child for this.
Removing the excess bits from each end of the sides board. The top edge of the board was then routed to 45 degrees for mitring with the top and the sides glued up to produce this.
I did started trimming off the furry edge on the veneers but then remembered, from my experience with Court of the Crimson King, that these are best left on until after the top is glued on. A sharper edge results from scalpel trimming at that stage. Well that’s today’s work. Its drying as we speak. The next thing to do will be the top pattern. Looking at the complexity of it I wish I’d got that done first. Oh well you have to start somewhere. So far, so good.
Be seeing you.
20 comments so far
13603 posts in 3340 days
#1 posted 10-21-2012 05:49 PM
your work is always so unique martyn
and the detail blogs
are very easy to follow
which is good
after the initial
‘HUH ….. HOW DID HE DO THAT’
don’t get to close to a window
don’t want you to get sunburned
and start peeling
View Ross's profile
Ross
30 posts in 2849 days
#2 posted 10-21-2012 05:55 PM
this facinates me! lovin it mart
-- after hours of labour, i've broken it more....but at least it's colourful!!!
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 3035 days
#3 posted 10-21-2012 06:00 PM
Parts of it scare the hell out of me!
View jap's profile
jap
1251 posts in 2053 days
#4 posted 10-21-2012 06:19 PM
i think all your boxes are amazing
-- Joel
View clieb91's profile
clieb91
3520 posts in 3934 days
#5 posted 10-21-2012 06:23 PM
Awesome to see it coming together.
CtL
-- Chris L. "Don't Dream it, Be it."- PortablePastimes.com (Purveyors of Portable Fun and Fidgets)
View mauibob's profile
mauibob
235 posts in 3066 days
#6 posted 10-21-2012 07:15 PM
This one is exciting to watch unfold (fold?), Martyn. Can’t wait for the next installment.
-- Bob, Potomac, MD
BritBoxmaker
#7 posted 10-21-2012 07:33 PM
Tape off and after a bit of a touch up.
View Ryan Haasen's profile
Ryan Haasen
385 posts in 2400 days
#8 posted 10-21-2012 08:46 PM
This is going to be AMAZING when it’s finished! I can’t Wait!
-- Ryan
View BertFlores58's profile
BertFlores58
1698 posts in 2921 days
#9 posted 10-22-2012 12:22 AM
This is another challenging task to add. Another amazing hexabox again.
Learned: 1) Good try in dying. 2) Veneering inside out. 3) Uneven elevation. (Yes, I’ve done this before..) and 4) Different construction of the cover. Thanks for the trade secrets revealed.
Waiting for the finish specially on the cutting of the half… lid and base.
-- Bert
View Druid's profile
Druid
1754 posts in 2794 days
#10 posted 10-22-2012 01:55 AM
Looks good Martyn. Can’t wait to see the top being produced.
-- John, British Columbia, Canada
View gfadvm's profile
gfadvm
14940 posts in 2689 days
#11 posted 10-22-2012 03:04 AM
Well done blog. You always make it seem so logical and straightforward that anyone could do it. NOT! Waiting for the top (looks challenging) and loving the looks of that dye.
View SPalm's profile
SPalm
5320 posts in 3881 days
#12 posted 10-22-2012 12:25 PM
Very nice Martyn.
You seem to had thoroughly thought this through. Just amazing.
The dyes came out extremely well. Sweet.
Steve
-- -- I'm no rocket surgeon
View Sheila Landry (scrollgirl)'s profile
9228 posts in 2919 days
#13 posted 10-22-2012 02:59 PM
So incredible, Martyn! :)
Sheila
-- Designer/Artist/Teacher. Owner of Sheila Landry Designs (http://www.sheilalandrydesigns.com) Scroll saw, wood working and painting patterns and surfaces. "Knowledge is Power"
BritBoxmaker
#14 posted 10-22-2012 07:29 PM
Thinking through the way to cut and veneer the top is proving challenging. I will prevail.
#15 posted 10-22-2012 07:49 PM
I have no doubt, Martyn! You know I am cheering for you! :)
Sheila
