This is the interesting bit. First the top, the easier part?!
I cut the centre sections out of the four Padauk strips. Book matched them, mitred them and glued up the above square. Yes I know theres a hole in it. I forgot to take the picture before I started the ‘boring’ bit.
Here’s the padauk top square with a pattern on it for centres of holes which are at the innermost part of the top slots. I could have done it by hand but as the plan was already in CAD I just printed off the relevant layer and glued it on (Pritt stick, stuff they let kids use to stick paper together with).
Centre punched the centre of the crosses and bored each kole out to 6mm, using a Forstner bit in the drill press.
Why do it this way?. Well the next item should make that more apparent. My jig for holding the top whilst I routed out the slots.
and bottom. The dowels are 6mm, 56mm apart, and are used to hold the top so
Next to the router table to route out the first two slots
Closeup
Routed from the outside to the inner hole on both sides. Held very firmly and advanced very slowly so as not to let the 6mm router bit snatch the piece. The first two slots done you just rotate the top around to the next two, route them and continue until all twelve are done. The jig grips against the inner of the pre-drilled holes for all of them. When finished you have this
The top then drops over the centre of the board to show this
Trial line ups of the side pieces showed I was on the right track
Now the ‘clever’ bit. The top is a very delicate flower and even glued to the base board I could forsee bits flaking off under EZ Mitring. So I pre-mitred the ends of the sides and the top on the belt sander. Table set to 45°.
Using a board under the top piece to stop anything flying off it. When placed together , upside down here, you get this
With all side pieces arranged aound the outside
The side pieces were then cut in half longitudinally and the sloped edges routed along them using a 60° router bit.
Close up
The top and side parts were glued onto the base board to give this
A couple of coats of spray acrylic
and corner pieces added in to steady the EZ Mitre routing
Sides trimmed off to length
Then mitred and glued up
There were furry ends to the coloured veneers, these cleaned up well with a scalpel to give a nice clean edge though. The pedestal base is as described in the Shell box blog so I won’t go into that here. Thats it basically..
The finished box is posted here.
Be seeing you.
-- Martyn -- Boxologist, Pattern Juggler and Candyman of the visually challenging. http://www.theartofboxes.com
12 comments so far
Jamie Speirs
home | projects | blog
3685 posts in 1029 days
#1 posted 236 days ago
Martyn that is incredible
the planning is just feat on it’s own.
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
Roger Gaborski
95 posts in 1920 days
#2 posted 236 days ago
Thanks for the detailed instructions. Another great box.
Roger
-- Roger Gaborski, http://www.gaborski.com, http://www.etsy.com/shop/RogerGaborski
SPalm
4120 posts in 2054 days
#3 posted 236 days ago
Clever one you are.
Very nice Martyn.
Steve
-- -- I'm no rocket surgeon
BTimmons
1103 posts in 657 days
#4 posted 236 days ago
You’re a madman, for sure.
-- Brian in Arlington, TX - Laziness is the foundation of efficiency.
bibb
286 posts in 1703 days
#5 posted 236 days ago
Martin,
Your problem solving skills are amazing!
-- "Imagination is more important than knowledge" Bibb in CO at http://katanadesign.com
woodklutz
198 posts in 940 days
#6 posted 236 days ago
Martin, as said by everyone”Just Fabulous”
p.s. I will not be attempting this.
-- honing my craft one mistake at a time.
Sodabowski
1821 posts in 1005 days
#7 posted 236 days ago
What Jamie said, most of all.
Your approach to routing the channels is very clever :)
-- Thomas - There is no such thing as a problem, there only are solutions.
Roger
9214 posts in 976 days
#8 posted 235 days ago
Martyn, you are a box magician. Wow! Very kool
BertFlores58
1539 posts in 1094 days
#9 posted 235 days ago
Martyn,
Mitering with those slots without the colored strips will be quite difficult as there will be nothing to hold it. Thanks for the idea. I can use this technique in lamination with acrylic combine with wood. Mind bodering.. that will keep my mind doing another designs.
-- Bert
gfadvm
6655 posts in 862 days
#10 posted 235 days ago
Martyn, You have an amazing way of coming up with solutions to insurmountable problems. Mitering the top with the belt sander was genius as was the ‘holder’ for routing the top. I learn something every time I click on Brit Box Maker!
Sheila Landry (scrollgirl)
5945 posts in 1092 days
#11 posted 234 days ago
Very cool, Martyn. Watching this process is so interesting. Thanks so much for taking the time to document it for us. :)
Sheila
-- Contributing Editor, Creative Woodworks and Crafts, Sheila Landry Designs http://www.sheilalandrydesigns.com "Knowledge is Power"
mafe
8057 posts in 1261 days
#12 posted 232 days ago
Clever, Martyn, clever.
Really a nice effect with the deepth in the wood.
Best thoughts,
Mads
-- Mad F, the fanatical rhykenologist and vintage architect. Democraticwoodworking.
