Jigs etc. #4: Snakes and Ladders - Hinge Template Routing Jig
Blog entry by BritBoxmaker posted 01-26-2012 05:45 PM 5186 reads 8 times favorited 7 comments Add to Favorites Watch
« Part 3: Simple Circle Cutting Jig for the Routing Table Part 4 of Jigs etc. series no next part
I’m just going to let the pictures tell the story here. The only things I will say is that the template guide pin must be exactly the same width as the router bit used (6mm in this case) and the minimum hinge pin width is also dictated by the router bit used. This is the test run with a 115mm square x 6mm thick piece of MDF being routed. No, even I don’t trust the actual pieces I am working for a project to the first run with a new jig.
The templates were marked out, using a knife, on a single piece of perspex (plexi-glass), the sheet cut in half and opposing ‘fingers’ cut out. Once these two pieces mesh all joints routed with them should fit and be identical. This jig could also be used for finger joints (box joints).
The name, as with most of my jigs, comes from things associated with atomic weapons and their testing. Not in glorification of this but more in the hope that something positive can be achieved under the same name.
7 comments so far
View shipwright's profile
shipwright
8000 posts in 2847 days
#1 posted 01-26-2012 05:54 PM
That’s a fine precision jig Martyn.
Incidentally, something very positive has already been achieved under that name ;-)
View BritBoxmaker's profile
BritBoxmaker
4611 posts in 3086 days
#2 posted 01-26-2012 05:56 PM
Ah yes, Paul. I was forgetting the two-piece swim suit. Thanks for reminding me. Hmmmmmmmmm
View degoose's profile
degoose
7237 posts in 3404 days
#3 posted 01-26-2012 10:48 PM
Very helpful.
View SASmith               's profile
SASmith
1850 posts in 3037 days
#4 posted 01-27-2012 01:18 AM
Very clever.
Thanks for sharing.
-- Scott Smith, Southern Illinois
View Sheila Landry (scrollgirl)'s profile
9231 posts in 2969 days
#5 posted 01-27-2012 12:03 PM
Wow! Thanks for posting this Martyn! So much work went into that design that many don’t realize it. The jig is very clever and it is nice that you take the time to share it with everyone. :)
Sheila
-- Designer/Artist/Teacher. Owner of Sheila Landry Designs (http://www.sheilalandrydesigns.com) Scroll saw, wood working and painting patterns and surfaces. "Knowledge is Power"
View mafe's profile
mafe
11734 posts in 3139 days
#6 posted 01-27-2012 01:01 PM
Happy to see positive things happen under that name.
Smiles,
Mads
View Druid's profile
Druid
1776 posts in 2845 days
#7 posted 01-28-2012 05:37 AM
Thanks for sharing, nicely done,
-- John, British Columbia, Canada
