Mondrian (inspired) #4: Neoplastic 'C' - Oh well
Blog entry by BritBoxmaker posted 10-21-2011 09:42 PM 5737 reads 1 time favorited 5 comments Add to Favorites Watch
« Part 3: Neoplastic 'C' progress Part 4 of Mondrian (inspired) series Part 5: I get knocked down, but I get up again »
I had a funny feeling about this.
I first made a mask to put over the board to measure it up for cutting into a net for the box.
This started as a CAD drawn outline printed over two sheets of heavy (160 gm/m) A4 (nearest to ‘Ansi A’ I think). I overlaid this on the board. Taping it down (clear tape).
Initially all looked well. As you can see it was not to be. Whilst 3 out of 4 corners worked from the point of view of patterns meeting on a box corner the one at top right was wrong.. I had made the Sycamore 3mm too long. There would be a miss-match at that corner. What to do?
I refused to panic and followed my planned course and began marking out the outlines with masking tape.
and then
Cut through the clear tape and freed the mask
Then took a closer look at the problem.
All I need to do is remove one piece of Padauk, one piece of Ebony, Cut down the offending 3mm of sycamore, glue on new pieces and re sand/finish.
Well I’ve started
Suffice it to say it went well. I’ll leave it there for tonight.
Be seeing you.
-- Martyn -- Boxologist, Pattern Juggler and Candyman of the visually challenging. http://www.theartofboxes.com
5 comments so far
View littlecope's profile
littlecope
3071 posts in 3372 days
#1 posted 10-21-2011 10:06 PM
You are not easily daunted Martyn!! Great perseverance!!
You’re going to get this thing, I just know you are… :)
View lanwater's profile
lanwater
3111 posts in 2804 days
#2 posted 10-22-2011 06:43 AM
What did you use for the cut. scrollsaw / fret saw? The material looks thin.
You definitely have a lot of patience.
-- Abbas, Castro Valley, CA
View CalgaryGeoff's profile
CalgaryGeoff
937 posts in 2352 days
#3 posted 10-22-2011 09:46 AM
This is going to be a box? Wow, no way, that is incredible!! I’m going to stick to cutting boards and leave boxes to the experts!! Great job thanks for posting it.
-- If you believe you can or can not do a thing, you are correct.
View David Craig's profile
David Craig
2137 posts in 2979 days
#4 posted 10-22-2011 11:54 AM
Considering the complexity of the piece, I would say this is a minor setback at the worse. Brilliant design Martyn. Mondrian would be proud.
View Cozmo35's profile
Cozmo35
2200 posts in 2906 days
#5 posted 10-24-2011 09:46 PM
Adapt and overcome.
-- If you don't work, you don't eat!.....Garland, TX
